Question about Cnet CNP 430 (CNP430) Print Server
Reset factory setting
I lost the password that was set for my CNP430 Print Server. How do I reset to the default
  • everton556 Dec 18, 2008
    The Print Server was setup with a password and i cant do anything on it without that password. However there is a default user name & password when it comes from the factory and I would like to reset that. It is usually a hardware action
  • Thomas F. Schneider May 11, 2010
    Have you attempted to reinstall the firmware and driver?
    http://www.cnet.com.tw/download/cnp430.h...
    President:
  • 1,566 Answers
Try consulting the manual for the printer:
http://www.retrevo.com/support/CNet-CNP-430-manual/id/8366bh135/t/2/
Posted on Jul 22, 2009
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
Run a cnet cnp430 on windows 7
I hope you are connecting the print server to a network hub or switch and not trying to connect directly to your Win 7 machine.
There are no drivers, a print server is a network device. Connect the ethernet cable from print server to your router. connect your printer to the switch. Search the network for the printer.
Apr 06, 2014 | Cnet CNP 430 (CNP430) Print Server
Reset password
Log in to your NETGEAR router by browsing to
http://www.routerlogin.net/orhttp://www.routerlogin.com./
Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults.
however, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection.
Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply.
If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
Sep 03, 2013 | NetGear ReadyNAS NV+ RND4000 NAS server...
How to reset a brother mcf-7420 printer?
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  2. From the main BRAdmin screen double click the appropriate printer.
  4. Click the Control tab
  5. Click the Restore Factory Defaults button
  6. Click the OK button when you have read the warning message.
  7. The print server will then reset back to its default values.
Via a web browser
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete. please rate it
Nov 29, 2010 | Brother MFC-7420 Printer
Factory reset brother nc 2010h
Same problem, did you find a solution ?
Pascal
Nov 11, 2009 | Brother (NC-2010H) Print Server
I already change the ip address of my d-link dp-300u printserver and then i accidentally remove the check in the the tcip selection, when i reset again i can't see my printserver. how can i reset it to...
Reset button is in back panel of printer sertver.
Press it for 10 seconds.
Then all settings goes to defaults.
Reset button is small round in back side of router you can press it's pin with any ball -pen.
Let me know if you need further assistance.Thanks.
Nov 11, 2009 | D-Link DP 300U (DP-300U) Print Server
Can't reset password D-link DP-300U
Can anyone tell me, what IP Address when reset to default? thx's...
Sep 05, 2009 | D-Link DP 300U (DP-300U) Print Server
Password
By default the DP 301P+ does not come with a password. If there is one installed (and you don't know what it is), you can reset the device to factory defaults from the Tools menu in the web configuration utility. Be aware that you will lose all settings in the print server when you do this.
Cheers
Nick
Nov 17, 2008 | D-Link DP 301P (DP-301P) Print Server
We forgot the password
try this and see if it works for you please email me and let me know first To reset the print server using PS admin follow the steps given below: ----------------------------------------------------------------------------------- Step 1 Open the PS Admin software, select the print server you wish to reset to factory defaults, and then click Factory Reset. Step 2 Click Yes. Step 3 Once the reset procedure has been completed, Click OK. The device is now set to factory default settings. For D-Link's preferred Home Networking application please try http://www.networkmagic.com/nmlp/dlinksupport.php from Pure Networks. It simplifies Microsoft Networking and may allow you to trouble shoot your network on your own. like i sai dtry this and let me know thanks keith
Sep 19, 2007 | D-Link DP 303 (DP-303) Print Server
Cnet CNP 430 (CNP430) Print Server Logo
680 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
