Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
While playing xbox 360 in 1080p mod, the screen frequently blanks
I have the xbox 360 hooked up to input 1 via component cables and the input and xbox are both set on 1080p. the screen frequently blanks out for a few seconds,(sometimes long enough for the input to have to reset. what could be causing this?
  • 2 more comments
  • NataleNoodle Jan 08, 2009
    I have the same problem. I have a brand new Sharp Aquos 42' Flat Screen and an Xbox 360. Every 10 minutes or so while playing a black screen pops up for a few seconds and then goes away. This did not happen before I changed it to the 1080i setting. I am using the HD Component cables included with the Xbox. I have tried setting it to 720p to see if this help and it did not. Please Help!
  • vegeta_17901 Jan 23, 2009
    the manual says that the tv does support 1080p over component though
    i have the exact same problem.only on 1080p not i.
    original 360. orginal microsoft hd cables. hooked into component.
    im not buying any addition products.not a hdmi converter..no new 360 with hdmi..i just bought this hdtv and i expect it to do this fairly simple task.
    for sharp being the leader in hdtv technology this is pretty sad
  • Anonymous Mar 12, 2009
    My 52'' Samsung blacks out when playing games in 1080p via the blue green red cables.
  • 26 Answers
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Posted on Dec 18, 2008
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
How do i hook my XBOX-360 up to this tv and get 1080i resolution? Thanks, Mike
You should be able to get 1080i with the Input/DVI port or the component video in ports of the TV. I believe the easiest option will be to set the XBox A/V switch to HDTV and use a component video cable (red, green, blue) from the XBox component out to the TV Component In. (with the audio out going to your TV or speaker system). Turn on the X-box and the My Xbox > System Settings. Then Console Settings > Display and chose the 1080i.
Set the TV Net Command (remote) and the Device settings for the input jack in use (component 1/2). Adjust the A/V menu for the Display before playing long.
Wen you change inputs, you will see a status screen for the settings for the TV input.
I hope this helps.
Sep 14, 2010 | Mitsubishi WS-48513 48" Rear Projection...
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Mitsubishi WD-62627 Projection DLP TV help with PS3
To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
Tv screen turns green after about 20 seconds on cab/satellite mod
called onkyo about this - plug into HDMI input 1 (DVD) instead of HDMI input 3.
Apr 09, 2009 | Onkyo TX-SR606 Receiver
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Green screen via analog connections
check if your input settings in the RXV663 for the S-video and composite are correct. Both connections are about the worst possibilities for video signal. What might help is powering of all other equipment not used when using XBOX or VCR, really powering off, not leave in standby.
Does your TV support analogue inputs? Than use them for the XBOX and VCR to connect directly to your TV for video, sound can still be connected to the yamaha.
let me know if it works.
Aug 08, 2008 | Yamaha RX-V663 Receiver
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
719 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
