Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brushes turn slowly only when the base is raised.
Hi, I just love this machine; so when there is a problem I am very upset. This is the first problem I've had since I purchased. I have a SpinScrub Heated Cleaner, ( F7000 series) I think. Well, the brushes won't turn when in contact with the carpet. I use this unit approx. 8-10 times a year. I always clean it very well after each use, including the brushes. I don't know which part needs replaced, if any. Please help me. Also I will need assistance taking this thing apart. I have relatives coming for the holidays, please hurry.
Thank you, Barb
  • 4 more comments
  • bmcnally291 Dec 18, 2008
    Bestdarngood, What roller are you talking about? The brush assembly connects to the unit via a square plastic rod that goes into the system. Where is the belt? I didn't know there was a belt.
    No grinding of any kind. It sounds like it always did. What does the square peg fit into? Also I should add, the peg is not worn, the edges are not rounded, it is perfectly square.
    Are you reading my comments? The unit IS clean! That is not my problem. Again What does the green plastic square rod on the brush unit go into? The corners on the rod are NOT rounded off, so contact is good. What ever drives the inside thing is losing power. What is that thing?
    Again there is NO unusual noise or smell. The brush unit (5 green round brushes that interlock with each other) does NOT spin when in contact with carpet.
    Even when the unit is off the floor the brush spins VERY slowly, and not at all when in contact with the carpet.
    Is there a separate motor which runs the brushes? I ask because everything else is working perfecting, it dispenses water and solution and sucks it up just fine, only the brush unit is not working properly. If it is a separate motor, what is the part number or part name?
  • Hoover Master
  • 19,396 Answers
The brush assembly is stuck with dirt and dust, if you have not fixed it yet, either the brush assembly must be taken apart, or replace the whole assemby.
If you have already fixed the hoover, then disregard this comment.
Posted on Jan 11, 2009
    Guru:
  • 449 Answers
Change the belt. theres is screws at the bottom 4-5 screws you will need a fillips head screw driver and as you lossen the screw the bottom should com apart and the belt is right there.
Posted on Dec 18, 2008
  • 679 Answers
It sounds like it is worn out mam, you might call a local repair shop in your area, they will most likelly tell you if it is worth fixing, most times with something that old, it's not worth fixing, sorry, Gym
    Brigadier General:
  • 5,158 Answers
Sounds like the motor is dying unfortunately. do the brushes spin before you put it on the carpet... when you are cleaning the carpet that puts some strain on the motor and it cannot handle that strain.
Robert
    Scholar:
  • 56 Answers
Hi mam may i know whats the brand? if its a hoover and 8 to 10 years of use the turbine could be the problem already which drives the brush is busted. It could be a belt or the brush motor is already damage, one thing is for sure if the insulation inside the turbine is already faded the ones keeping the wires from short circuiting and makes a magnetic field that makes it spin, please do not try pluging it in again you dont want to risk short circuiting or starting a fire. and i really Really need to know what exactly the detail is to help you you more, like is it making a sound like an electricuted sound or do you smell if something electric is burning because if you did its already damage and you could find a rewind shop to rewind the coild of the turbines. i hope this helps thank you and fixya.
  • 75 Answers
It has removable Rotating Brushes...near that Two separate translucent tanks will be there to keep clean solution and dirty water separate..it seems you have to clean it...so clean and fix it back and then check it out....this may be the problem
  • 3,037 Answers
Well either you have hair or something getting caught in the roller or the belt has gotten worn out and needs to be replaced as it has begun to stretch.
If you need help finding a replacement belt, let me know otherwise the manual should give you a number to order from
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Dec 18, 2008
    Ok, this is the one with the Turbine Gear Assembly which is the most likely problem. Is there any grinding or anything coming from the machine
  • Benjamin Patri
    the peg goes into the turbine gear assembly, when not contacting the carpet, is the brush still spinning like it used to or is it spinning just the same speed as if it is on carpet
  • Benjamin Patri
    I told you already, the TURBINE GEAR ASSEMBLY is your problem or the motor is your problem. To diagnose which one is the problem, let me know it it doesn't work while not on any surface. If it acts the same without working on the carpet, then it is the gear assembly that is the problem and needs to be replaced as you probably sheared off a gear.
Why are the brushes turning until they are placed on the carpet?
The brushes are not powered by a motor but by the exhaust of the vac motor. They must have lots of air to even turn at a slow RPM. You may have a lint blockage on the air which cuts the volume of air to the turbine that spins the brushes. Look for lint on the filter. I recall it was on the operators left side on the base of the machine towards the front.
Jul 06, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Help! I got a shoelace hung in my Dyson, turned it off pulled shoe lace out, now the brushes will not turn. There was no smell, I thought it was really nothing. Dyson sent me a new head and still don't...
Hi William, it's Jack at Dyson.
I've just replied to you via the email address you've supplied. I'll look forward to hearing back from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Sep 14, 2013 | Dyson Dc 25 Animal Upright Bagless Vacuum...
My hoover Model F5858-920 bushes stop turning how can i fix it?
1. Check to be sure recovery tank is on right. This is the problem 99% of the time the brushes use a turbine powered by the suction.
2. Check to be sure the brushes are set to "on" if it has that option. And that the screen filter on the front of the machine is clear.
3. Check the brush block by pressing the 4 tabs holding it in place under the machine. It will slide out. It should turn easily. If the tab to turn them is broken they will not work either. This is what they should look like:
http://www.vacuummedic.com/product.php?id=206
4. Place a screwdriver in the socket that turns the brushes, it should turn slowly but fairly smooth. It should not make any grinding or foul noises while turning or if it is frozen solid it is bad. This is the replacement part for that:
http://www.vacuummedic.com/product.php?id=229
The Vac Dr.
Sep 09, 2012 | Hoover Steam Vac Carpet Cleaner Spinscrub...
Hi my dc07 has lost suction on the roller, but not on the hose there are no blockages cyclone still strong any ideas thanks
Are the brushes in the base of the vacuum spinning? You wont get much suction from the base of the hoover if the brush bar isn't working?
Lie the vacuum on it's side and turn it on. If the brushes aren't spinning then your belt has either come off or broken. I suspect this is the cause of your problem.
Nov 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My brushes on my Hoover Steam Vac stopped spinning again! I took the brushes out and they turn fine, but when inserted back into the base, they do not turn, AGAIN! Anyone know what the problem is and...
Tip is slightly, do the brushes spin then? If so, then the brushes are air driven. By the spin indicator at the front of the machine, you'll see a small screen (same type of thing as is in your dryer), scrape it, you'll probably find there's a build-up of fluff. Clean off the fluff, and try again.
Nov 01, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes won't turn on my hoover steam vac dual v
Hi There,
Unfortunately the answer above is far from helpful. The filter has absolutely nothing to do with your brushes not spinning, and you can really replace the turbine yourself without having to take it into a shop to fix it. Here's a much more helpful diagnosing of how to check the brushes, and fix the turbine if needed.
There can be serveral things that may have gone wrong with your Hoover so that the brushes stop spinning. Unlike the other "expert" above I will walk you through step by step on how to diagnosis this problem, and fix it. Unfortunately there is no belt or band on this model, but instead it's actually a turbine assembly that drives this brush.
Possible Problem #1. Usually the most common problem when the brushes stop spinning is that the brushes have simply gotten clogged with something that is preventing them from spinning. Especially if you have pets in the home, this is a common problem. Here's how you can clean these brushes.
First, turn the machine upside down so that the brushes are facing upwards. Pull down on the upwards on the brushes and they will easily snap right out of the mahcine completely. . Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. It's important to make sure that the brush switch on the top of the machine is turned to "Rotating Brush Speed Hi", and that the handle of the machine is reclined down. There is an internal switch inside the machine that turns the brushes off when the machine is in the upright position, so you'll need to step on the handle release pedal to ensure that this switch is engaged. Hopefully the brushes just needed to be cleaned, and they will now work now that you have reinserted them. If this still didn't fix your problem, move on to the next possible problem.
Possible problem #2: If the cleaning didn't fix your problem, remove the brushes from the machine again. Once the brushes have been removed, the handle reclined, and the brush switch turned to fast, turn the machine on. Where the brushes were sitting you'll see a square shaped hole (pictured below) that the brush stem fits into that actually spins the brushes. This part should be spinning while the machine is on. Here's a picture of that part:
If this part is not spinning, then your Turbine Gear Assembly has gone bad and needs to be replaced. If this part spins however, then this indicates that your brush block is gone bad, and needs to be replaced.
Here are links to the exact parts for your model that may need to be replaced:
Brush Block:
http://www.govacuum.com/hov2st6blpa4.html
Turbine Gear Assembly:
http://www.govacuum.com/hostretubrge.html
Here's also a link to a Fixya repair solution that I've done explaining step by step how to replace the turbine gear:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
I hope this helped you, please be sure to rate the repair or leave feedback if you found this repair to be helpful.
Thanks so much,
Chris Jones
GoVacuum.com
Jan 12, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
Cleaning brushes spinning very slowly - no power
Please check the inlet screen for hair or fiber obstruction. On the base of the cleaner, behind the brushes, there should be a red panel, about 1 1/2 inches wide. Squeeze the two tabs together and pull down to remove from the pocket. Clean off this metal screen filter.
Oct 02, 2009 | Hoover F7431-900 SteamVac Vacuum
I have a hoover steamvac model # F5915-900 and the brushes are not turning when I turn the selector from off to low or high. I've checked to make sure the brushes are locked in place and they turn manually...
(1) Remove the brush assembly by pulling/unlatching it from base on each side.
(2) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(3) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Sep 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Apr 28, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
14 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
