Question about Whirlpool Refrigerators
Water freezing in bottom of freezer
Water freezes in the bottom of the freezer then thaws and leaks on to the floor.
    Problem Solver:
There is a drain for your freezer that is pluged.It may be pluged with ice or dirt.Try unpluging your fridge until it is completely defrosted,4 to 5 hrs. with doors open.
if there is dirt in it it may flush out or your heater element for the defrost is not working.
Posted on Dec 18, 2008
2 Suggested Answers
AndreaBl
  • 218 Answers
SOURCE: water leaks into bottom of freezer. it re freezes, and then also
hi there,
there a leak somewhere in there. there is no way you can fix this yourself, call the repairman or LG's customer service.
Posted on Jun 11, 2010
Water is draining and freezing from the freezer and leaks onto the floor
This is an easy fix! First either remove the back access panel or remove the interior freezer access cover. You can reach the drainline from either side. What has happened is your evaporator drain line is clogged. You will need to use a blowdryer to thaw the ice blocking the drain line. The drain line is located at the bottom of the freezers interior back wall. All you will need is a long screwdriver/clotheshanger. Once you have thawed the line stick your screwdriver/clotheshanger and unrestrict the line. I hope I helped you.
Aug 31, 2010 | Refrigerators
I have a Roper Frost Free top freezer model Model@RT16DKXXW06 Serial#EB2423742 Type#16ATR92 Mfg 06/92 the pats 6-8 weeks it has been leaking water on the floor I assume from the defrost cycle. What can I...
yes the drain is in the rear of the freezer ..you will need to remove the covers on the bottom and the back to see the drain..remove all the ice buildup on the bottom ..then use hot water to thaw drain...the reason for the line freezing up is freezer is set to cold freezing leftover water from defrost..let me know good luck/joe/
Aug 27, 2010 | Roper Refrigerators
The bottom on the freezer side has water leaking and it freezes on the bottom floor and leaks on to the outside floor
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Aug 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Water leaks into bottom of freezer. it re freezes, and then also
hi there,
Jun 07, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
GE Monogram refrigerator is leaking water on the floor
At some point the freezer got too cold and the drain froze (it is a poor design with a loop in the bottom). Once this freezes it will not thaw for a long time.
Here is what I did:
  • Remove all items from freezer and let it completely thaw
  • Pull unit away from wall to access rear
  • Cut loop off drain line where it hangs in drain pan
  • Place a bare copper wire (#12 will work) through the drain line and wrap it loosely around the heating coil above drain pan
  • Enjoy
Did this 6 months ago and have not had problem since
Mar 15, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Refrigerators Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
