Question about Sony PFM-50C1 50 in. Plasma HDTV
Weird /not the right colors on screen
My sony pfm-50c1 was working perfectly until i powered it on and noticed all of the colors are bizarre. i was running a visualization studio with music earlier, do you think this could have wrecked the screen due to the changes in colors? I've tried unplugging it and changing power sources and its still doing the same results.
  • veriluxxxx Dec 18, 2008
    the colors are mostly magenta and light blue, with some neon green and yellow thrown in the mix
    Dan,
    I tried to hook up another VGA connection from my computer to the plasma and its showing the same off/bizarre colors but mostly yellow. Before that I hooked up a xbox 360 from component male to female coupler RCA to VGA to component male. Both were working fine for the past couple of days, I dont understand it
I had the same problem and found out that my kids had been messing with the remote control and put the screen saver on (not the first screen saver option but the second option which make it look kinda like a photo negative) i disabled it and got my normal picture back.
Posted on Jul 08, 2009
  • 4,234 Answers
It is not likely that anything played through would effect the unit other than perhaps a burn-in image if you displayed the exact same image for an extended period of time. Can you better describe the "bizarre colors"? In what way are they off?
Thanks,
Dan
Posted on Dec 18, 2008
  • ABRsvcs Dec 18, 2008
    If I understand you correctly, the colors appear to lean toward the purple side correct? If so, check to verify that you are sending RGB signals and that the set is expecting RGB. Leaning toward the purple suggests that you are sending RGB and the TV is expecting component (Y,Pb,PR).
    Keep me posted.
    Dan
SONY PFM-50C1 WONT POWER UP, STAND BY LIGHT COMES ON, AND THEN IT SHUTS OFF
sir do a power reset, turn off the tv, unplug the tv from the electrical source, wait for about a minute then turn the tv again, if the problem still exhibit call 1800 222 7669 thats for sony customer service,.
Oct 30, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-42B1E plazma screen
Does the red standby light flash ?? If so count the flashes and see my error code section.
Jul 05, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-50C1 50 in. HDTV
Hello MDay02,
Here is how it works. When you finally decide that you want to purchase a board from us, We will send you a Pay pal invoice with the Total cost. We will also give you our contact number after payment is received, which will come in handy if you need assistant in installing the part. Assisting in installing is unlimited to that particular part. You can call us as many times as you want.
Best regards
circuitcity
Apr 09, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony Plasma PFM 50 ci black screen
. Check blink of leds
check the 5 v control voltage.
check Ysus and Zsus board.
check Voltage sc, Vs and Voltage a .
Yareth De Matos - Venezuelan -
Mar 28, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony plasma picture is blurry and makes a popping noise
Hello MDay02,
Your problem maybe your X board which is the same as PCB X sustain. Changing the fuse in this case may NOT solved your problem. If you are handy, you may be able to change the board yourself. We have most Sony X board in stock. If you purchase the board from us, we will walk you through the installation process for FREE over the phone.
Mar 17, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony plasma
SOUNDS LIKE YOU NEED A NEW PDP(PLASMA DISPLAY PANEL) HOPE YOU HAVE WARRANTY$$$
Feb 19, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-50C1 Fuzzy Dim Display
Just want to let you know that the problem you are having is a bad X board. This board may not be available from Sony, because it is sold as part of the panel
Best regards
CircuitCity
Sep 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Vertical Black line on display
Rakesh, You have a "dual scan" panel, this is why the line only decends down the screen half-way. This could be a connection problem on the buffer board which causes loss of the drive signal only to that part of the display which it is connected to. The vertical address buffer will be located on the top rear of the display, use great caution in inspecting these cables and connectors. If the integrity of the cable and connector is good the panel itself may be bad due to the drive IC being located on the ribbon cable attached to the panel body. this is better known as COF or, chip-on-film technology. I hope this helps you. Good luck. Joe Weibel CustomElectronics.Org
Jan 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-50C1 50 in. Plasma HDTV Logo
265 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
