Question about Honeywell Programmable Thermostat Heater
Heat pump that just blows cool air
I have a Janitrol A24-05 Heat Pump with a Honeywell T8085D thermostat. When I set the thermostat to turn the heat on all I get is cold air blowing. Any ideas?
  • 1 more comment
  • wggrimes Dec 18, 2008
    I'm hoping it's the condensing unit circuit breaker since that would be simple. Where do I look for it?
  • Anonymous Dec 18, 2008
    The outside temperature is in the 40s and there is no back up. Where would I look for the condenser unit circuit breaker?
  • Anonymous Mar 26, 2014
    When I turned up the thermostat yesterday the pump screeched and finished with a bang. Now there's no heat coming through the vents just air from the circulating fan. Emergency heat on now and running.
I have a Honeywell heater i'll set my thermostat to 76 and ill turn on the heater and it would turn on... but when it get to 76 it turns off so when the temperature drops down and the heater clicks back on all i get is cold air .. it only works on the 1st time what to do ?
Posted on Dec 24, 2008
  • 24 Answers
Is the condenser operating? what is the outdoor temperature? A heat pump is a cooling system with a reverse gear, most reversing valves which make this possible fail to the heat mode so it is not likely to be the problem. You should have either gas or electric back-up heat. If you switch to emergency heat do you get warm air? Really need to find out more to make an informed guess at your problem, the simple stupid would be is the circuit breaker to the condensing unit possibly tripped or shut off?
Posted on Dec 18, 2008
  • Brian Markstahler Dec 23, 2008
    sorry for the delay, condenser circuit breaker should be in your main electrical supply panel, there can also be a fused or circuit breaker type service disconnect outdoors by the condenser, should be a gray box with a door,.
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
Honeywell thermostats keep turning off and on and blowing cold air
Need to know the type of heat you have. If it is an air to air heat pump, with this cold weather, you are not going to get much heat out of it. It will feel cool (a little higher than room temperature). If the temps outside stay below 25 degrees, then switch it to Auxillary (Emergency ) heat.
Nov 25, 2013 | Heating & Cooling
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
Armstrong Concept 12 heat pump blows warm air when the thermostat is set on cool
likely in the configuration need to change when the reversing valve is energized. sometimes energized when in cooling ,sometimes when in heating. whatever yours is on its likely the opposite.
Nov 12, 2017 | Heating & Cooling
My honeywell heater thermostat is only blowing cold air, there is no heat blowing regardless of setting. how can i fix it? it won't even turn off.
the wiring for thermostats are color coded. R(red)power, Y(yellow)cooling, G(green)common, W(white)heating. O(orange), E(emergency)heat. Make sure that you have the right thermostat because there is an air condition thermostat and there is a heatpump thermostat and they wire up differently.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
Apr 24, 2010 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,099 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
