Question about Oreck XL2200 Bagged Upright Vacuum
Oreck XL Leaks Dirt At Bag Entrance
Our Oreck XL has had a problem since day 1 leaking dust at the entrance to the bag. It's much worse as the bag gets full. It seems like something is wrong where the plastic engages witht he bag seal. It's not tight and the whole assembly is floppy. I've used rubber bands around the plastic housing that engages with the bag to tighten it up but it hasn't solved the problem. I'm wondering if we're missing a part as this can't possibly be normal.
  • laura442 Jan 31, 2009
    I have also the same problem and it is a push on
  • Anonymous Mar 30, 2014
    the tubes on the back of the vacumn cleaner are not tight and dust is coming out. I took off the handle, but the tubes still do not tighten.
Do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
Posted on Dec 22, 2008
  • Paula Bamford
    Paula Bamford Jul 13, 2014
    I've got the same problem, continue to reattach the bags all the way through vacuuming the house, have spent ages fixing the docking back for it only to pop off again half way through the next room. Non of the answers on her help at all, is there an oreck servicing option?
    New Friend:
Push on bag.
Posted on Jan 23, 2014
Outer Oreck xl bag is full of dirt
Make sure that your bag is pushed all the way past the lip on the connector tube and that the "U" shaped part of the plastic assembly is in it's slot behind that lip, or it will not seal properly and you will get dust into the outer bag.
Mar 21, 2014 | Oreck XL2200 Bagged Upright Vacuum
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I have a docking station on my Oreck; I am having a very difficult time putting in a new bag.
My oreck xl was leaking bad at the internal bag entrance. I found out that the outer bag was not seated in all the way to where it snaps completly over the retainer lip on the plastic part on the tube. Once I did that, I then put the docking station on, again making sure it was seated all the way, and finally the inner bag. The problem was alot better.
Apr 01, 2011 | Oreck XL2200 Bagged Upright Vacuum
My Oreck XL is shooting dust out from the roller when I try to vacumn
This is a sign that the bag is full or there's a clog in the air flow piping. Check behind the brush for clogs and remove if there is. Open the cloth bag, remove the paper bag, and check inside the tube. If no blockage is visible, drop a coin or marble down the opening and see if it rolls out. If not, there's a clog that needs removed. You can use an air pressure hose to blow it out..
Feb 16, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL vacuum does not have enough suction to pick up dirt. Any suggestions to remedy this problem? The belt is strong, the bag is not full, and there do not seem to be any obstructions.
Turn the machine on and be sure the bag expands quickly and fully like a balloon. If the bag does not fill with air, or is soft, there is probably an obstruction inside the handle tube or fan housing. Disassemble the handle to check for blockage, or remove the bottom plate to check the inlet to the motor fan.
Jan 19, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Dirty Oreck bag
yes but separately from other clothes
Aug 09, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Dirt smell
If this thing has a fast-spinning belt in the "head" of the unit, you are smelling the dust that is being collected in the back of the little drive "chamber" and is being heated up by the motor and the friction of the belt. This is a pretty common thing on vacuum cleaners designed like the Oreck. If it is huge bunnies of dust, well then that means there is a leak somewhere...
Mar 11, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Generic problem for all Vacuums
Posted by FISHERMAN928 on Jul 06, 2008
Older Oreck XL, new belt, new bag, checked for clogs, does not pick up
as it used to, and, much harder to push, seems to grab or drag, why????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that may work. Depending on if you have the old style brushroll you can upgrade to a new style Oreck brushroll that has twice the brushes and will a work a lot smoother. Also, clean the bottom plate – get rid of any dust and dirt build up and then spray the bottom with silicone and let it dry after you have totally cleaned it. Always use Oreck genuine belts and to change the belt every 4 to 6 months for the best cleaning and store the extra Oreck belts in a Ziploc bag in the refrigerator, other wise if you have a new belt, gag, you have checked for clogs there is no reason why it should be hard to push, if the silicone does not work replace the bottom plate. Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Dec 28, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
1,183 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
