Question about OKI C9200n Led Printer
Fatal error 141 magenta drum on oki c9200
I took out the drum and ink cartiridge apart - and the most of the ink fell on the floor...(powder that is )
i have read that i should try and replace the drum - unit with another color(eg. cyan. to see if the error moves to 140 or 142.. to see if magenta drum is busted )
any suggesstions if i should do this ? or something else first
CompuGuy44
  • 432 Answers
SOURCE: fatal error 141
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum. Did you already get this fixed?
Posted on Jun 25, 2007
  • 3 Answers
SOURCE: Sensor Error
About the croaking noise:
The drum unit, underneat the toner cartridge, at the left side (seeing the machine from the front) has a kind of a pump device, made with an internal small belt (you can't disassembly it), its function is to move the old used toner, that exit the cartridge from the left hole, into the springed plunger, the toner moves into that chamber and is pumped back into the cartridge. In time that chamber receives so much old toner that the small transporter belt inside can't move anymore, it makes a very high load to the pulleys and they jump tooth, so the noise. You may want to disassembly the drum unit, (as reference the yellow p/n is 42126601), and get isolated just that chamber, there is only one small plastic geat that moves the pump inside. The gear must rotate somehow free, if not, try to such old toner using a vacuum cleaner, but you will need to keep rotating the gear by hand to pull out all the bad toner. It may exit from the bottom hole or from the spring loaded plunger on top (when pulling the spring). If you are lucky you may have it working back again, if not, prepare your dollars bills to replace the unit. The croaking you are listening may be cause by this or it may be a wrong drum unit you installed into the machine. Check the gears between the old and new units. Good luck. Wagner.
Posted on Jan 14, 2008
leroyal
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
  • 24 Answers
SOURCE: getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
Posted on Jan 24, 2010
don_farr
  • 1018 Answers
SOURCE: REPLACED OKI C33OO'S CYAN TONER CARTRIDGE AND
Are you using a third party toner cartridge or a refilled cartridge?
If you are, DON'T!
Don
Posted on Jan 29, 2010
Printing is too light on deskjet 3845
Try the solution below :
Open the printer cover and remove the toner cartridge, one by one. Don't remove them all at once. Place one hand on each end of the cartridge and keeping the cartridge level(flat) with the floor, rock it back and forth (not end to end). This helps to distribute the ink powder inside so that it evenly contacts the drum.
Remove each color cartridge, rock it to distribute the powder, then keep it level while you re-insert it into the printer.
Hope this helps. Don't forget to rate my response.
Jul 22, 2010 | HP LaserJet 2605DTN Color Printer
How to refill ink in it
The printer doesn't use ink, it uses toner, a black powder. The toner is then pushed onto the page using magnetic force and fused to the paper using a laser. Which replaces the traditional "ink injection" method.
The toner cartridge is a black unit that pulls out located behind the top access panel in the front. This unit contains a glass drum and behind it a well of toner powder. Usually you have to replace the entire unit.
There are toner cartridges with plastic caps which can be removed and then refilled with the powder. However, this powder is messy, difficult to manage, and eventually the drum will become scratched and worn since it is not really designed for prolonged use. So I recommend just replacing it.
While the toner cartridge will run more than ink. The frequency with which you have to replace it is significantly less. So while ink can run you as much as $0.25 a page when you factor in the wear and tear on the printer. Laser printers are more along the lines of $0.04 a page.
If you replace the toner, read the directions carefully and be sure to remove the plastic shipping strip from the side of the cartridge. This strip is used to hold the toner in the cartridge while it ships and will keep it from working properly.
May 12, 2010 | Canon LASER SHOT LBP-2900 Printer
Replaced fuser and toner units now only prints black pages
Printing on a laser printer has 3 steps:
1. electro-statically charging the "drum", at various tiny "pixels",
to identify where the toner-powder should be placed.
2. feeding toner-powder onto the charged drum.
3. making the fuser produce heat to "bake" the ink onto the printer.
So, a failing unit or failing electronics would "charge" *ALL* of the drum,
thus putting black ink EVERYWHERE onto the page.
Take the printer to a qualified technician.
Nov 13, 2009 | Epson EPL-N3000 Laser Printer
Hi, I have a Lexmark X7170 Multi-function printer/copier/scanner and it is showing an error message "left cartridge incorrect". I have not charged the cartridges and I have tried to re-align it. Any ideas?
it means your left cartiridge got some problem, might be it got short and you have to replace that.
try this remove your left cartiridge and then try to print if it work then its clear that your aother cartiridge is gone and you need to change it.
Oct 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Rear drum bearing
When it is like that you usually need to replace the drum bearing.
Ifthe tub recently started making a lot of noise, and you can feel thatthe bearing had too much play when spinning by hand, that means thatthe drum bearing needed to be replaced.
You can find the replacement part and the schematics here.
See also :
Mar 07, 2009 | Hotpoint NWXR473EV Dryer
Canon Pixma MP 780 is printing green
check the cartiridge for ink ( epecial for the black cartiridge) try ro refill or replace to new cartiridge
Nov 11, 2008 | Canon PIXMA MP780 All-In-One InkJet...
X73 found loose spring
I was having a similar problem. After finding the service manual (4402_X73.pdf) and taking the thing apart, an ink-covered broken spring fell from the inside. I checked around the 'Maintenance Station' and found the other half still hanging. Apparently -because I haven't got a replacement yet to confirm- the spring goes across the bottom of the 'Maintenance Station' to a lever on the other side. If someone can tell me where to post a picture of the thing, I'll gladly do it.
Jun 21, 2008 | Lexmark X73 All-In-One InkJet Printer
No cartiridge
generic ink? If yes, the cart circuit board has a short circuit. This cant be repaired!
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000087/faq002487_000.html?reg=us&c=us&lang=en&prod=mfc440cn_all
Apr 28, 2008 | Brother Multi-Function Center MFC-240C...
OKI C9200n Led Printer Logo
145 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
