Question about Compaq Evo N610C Notebook
Battery run out soon
Please tell me what to do
  • 26 Answers
You probably need a new one. Take it to a computer store and have them test your battery. They should be able to do this from your laptop. Rechargable batteries tend to die and hold less charge over time.
Posted on Dec 18, 2008
What is the problem with my mazda sting 160i 2002 model as soon as i use electrics like lights, wipers etc, the battery runs down. i've replaced battery, regulator and alternator 3 times already. It runs...
remove negative cable from battery, hook up a test light to the negative terminal. opposite end to negative on battery. start pulling fuses, when the light on tester goes out. thats the bad curcuit that is draining battery. wait about 3 minutes before pulling fuses. Good-Day!
May 13, 2014 | Mazda Cars & Trucks
My dell inspiron 1501 will charge the battery but as soon as i unplug the laptop turns off.
It's either the battery or charging circuit on the system board. If you have replaced the battery with a new one then it's probably the system board. A new system board could run between $150 to $300. Then there's the coat of labor.
Feb 17, 2013 | Dell Inspiron 1501 Notebook
My bike only runs when being jumped off. when you take the jumpers off the bike quits running. I dont believe its the battery because I have charged it and it started the bike, Then died. What can I do so...
Hello, you will find that your battery is the problem. While it is starting your bike, it is not holding its charge, very common with batteries. Have it checked out with a load tester, this will tell you if it is holding voltage under load. You can also give it a quick test with a normal multi meter, select volts on the multi meter, check the voltage on your battery before you start, it should be in the mid 12s, start your bike with the bikes battery (do not jump start), as soon as the bike starts check the voltage again, it should be in the high 13s or 14s, if it is lower than your first reading (12s) than your charging system is faulty, stator, voltage regulator etc. It the reading is in the high 13s or 14 than your charging system is ok (it is telling you its charging), when the bike cuts out check the battery again, you will find the reading is lower than 10v (if the battery is faulty) good luck.
Feb 17, 2011 | 1985 Honda VT 500 C Shadow
I own a Honda CRV 2007 model. The battery just died, what type do I ask for? Will most dealers know if I simply state year make and model of the car I want the battery for?
THE DEALERSHIP OR AUTO PARTS STORES CAN FIND WHAT BATTERY YOU NEED.JUST TELL THEM MODEL YEAR TYPE OF VECHICLE.ENGINE SIZE AND TYPE OF FUEL INJECTION SYSTEM.HAVE ALTERNATOR CHECKED OUT WHEN YOU BUY ANOTHER BATTERY BECAUSE BATTERY JUST 3 YEARS OLD.THEY CAN LAST 5 YEARS.IF BATTERY FAILS TOO SOON IT COULD BE DEFECTED BUT HAVE ALTERNATOR CHECK.WITH ENGINE RUNNING ALTERNATOR OUT PUT SHOULD BE 13.5 - 14.5 VOLTS.
Oct 07, 2010 | Honda CR-V Cars & Trucks
Battery in message center continues to flash ON with engine running and Amp gauge indicating 14 amps
That battery light means that the alternator is not working properly, you can take it to a shop to get an avr test which will tell you forsure.Or replace the alternator. I would do something soon, the atlernator will wreck your battery & leave you stranded on the side of the road. Good luck
Jul 13, 2010 | 2002 Chevrolet Avalanche
I was driving and all of a sudden my car cut off and wouldn't start. The only way it would start is by jumping it off, but it would soon cut off
sounds like either your battery or your alternator has gone bad....if you can get it to an auto parts store they can check it out and tell you which it is or both....
Feb 02, 2009 | 1997 Cadillac DeVille
Low battery signal
If you camera still tells you that you have low battery. It is possible that the battery that you put it was not desinged for digital cameras. Please try batteries that are specifically designed for digicams. You can ask store personnel this when you buy batteries.
Oct 04, 2008 | Cameras
Battery Not Working
Take your watch to a reputable watch repair ( NOT A JEWELER) you should be able to find one in the phone book. The price (depending on where you live) should be between $8.95 and $12.95. Tell the store to CHECK your battery, NOT replace it at first because that is exactly what they will do , and sometimes it"s not the battery that is bad . You may a mechanical problem and when you change the battery, it will run good for about 3 weeks and than it will go back to having the same problems again and you've just waisted your money. If you have anymore question, please feel free to ask, I will be glad to help you. Good Luck!!
Aug 12, 2008 | Watches
Will not charge battery
Please contact the nearest Authorized Sony Service. If you need more info please advice. Arpi
Feb 16, 2007 | Sony DSC-T7 Digital Camera
Compaq Evo N610C Notebook Logo
18 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
