Question about Samsung Digimax i6 PMP Digital Camera
Camera not switching on
Hi, my camera had a battery low and soon switched off i kept it on charge over night and and next day when i came back from college i took it off charge and it does not seem to switch back on again. can u plase help me fix my camera back thank you
  • 944 Answers
Sounds like the battery has failed. if you can, then if you can try and borrow a working battery from someone else with the same camera, and try your battery on their camera just to confirm this is the problem. If you can't, then just try a new battery - please post again if you are having trouble finding one. Other possibility is that there is a fault with the charger - again if you can borrow one, you can soon see of this is the problem. Most camera repair shops will have a selection of chargers they can use, so you should be able to check this quite easily. Hope this helps :)
Posted on Mar 28, 2007
2006 HYUNDAI TUCSON BATTERY DIES EVERY NIGHT!
try checking trunk light I serviced a lot of draining battery problems . I had one the other day the customer states every 4 days need jump start . 1st step ck charging system ok , starter draw was good . started to ck all drains all were normal . after dealing with this issue for a month i replaced his battery with a new one he never came back . calls me for reg service . A week cell in battery can pass the test . Hope this helps .
Mar 12, 2013 | Cars & Trucks
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Hello sir, I have olympus C-70 model which is working very good for last 5 years. I am on vaction to france and it worked well till last 2 days. I have switched it off 2days back and switched on last night...
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Aug 23, 2009 | Olympus Cameras
On the samsung p1000 digital camera charging is proving a problem. An orange light keeps blinking when the charger is connected and the camera remains uncharged and will not switch on
had the same problem! brand new camera, never had it switched on and it just kept blinking.
took battery and card out, put battery in then tried to charge. same orange light.
put card back in and took battery out for min and replaced, red light is on now!
hoping this has done it. will try camera in few hours!
Nov 21, 2008 | Cameras
Showing battery low
hi anjali,
i think the problem must be with the replacement of the CCD chip. they must have must some damage to the cam with out their knowledge. but the thing is you cant even claim that with Sony. you must have took it right next day.
that too if you are in india you cant expect the service people to get these things fixed so soon. you must have been attentive.
Nov 14, 2008 | Konica Minolta DiMAGE A1 Digital Camera
When the camera is on it's base and plugged in you can view a slide show. when it is not plugged in you can not switch it on to view anything or take any pictures but the green light still works when you...
The camera's charge-couple device (CCD) within the camera must have suffered a short-circuit due to the sea water, rendering the imaging device damaged. As a result, the battery would drain pretty quick while its switched on.
Please take the camera to the nearest service center to have it repaired.
Thanks!
Sincere-One
Jul 21, 2008 | Fuji FinePix S7000 Digital Camera
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Flashing Low Battery
Let me know if you have a solution...Mine just started doing the same thing
Dec 11, 2007 | Nikon D200 Digital Camera with 18-200mm...
Switches off
there are some power supply circuitry inside, one of those electronic chips maybe damaged.let it be service by qualified tech. Fred Loja
Jan 26, 2007 | Fuji FinePix S5000 Digital Camera
Open Questions:
Samsung Digimax i6 PMP Digital Camera Logo
93 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
