Question about Maytag 24 in. MDBH955AW Built-in Dishwasher
Lock on light flashing on Kenmore Dishwasher
The Lock On Light is flashing on Kemore Dishwasher and it stops working. I opened thre front panel and unplugged the Ribbon Cable and plugged it back and then pressed the start button and at that point the dishwasher started working. It lookes like one of the contact on the ribbon cable is loose. Is it possible to get the replacement parts for the Kenmore Model 15979992, Serial Number FK1713415?
SOURCE: "3 second" light flashing
The 3 second flashing light is a lock that locks out all other functions. To disable, depress the 3 second light for 3 seconds and all the functions will be released. This feature is to use to keep little kids from starting the appliance.
Posted on Jul 04, 2007
  • 1003 Answers
SOURCE: Maytag MDBH950AWS Dishwasher won't start
REPLACE TIMER
Posted on Jan 18, 2008
SOURCE: Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Posted on Jan 21, 2008
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
How to fix front light panel flashing? no buttons are working
on some makes, plugging it back in while holding in the on/off button will reset panel. cannot hurt to try. good luck.
Mar 09, 2015 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
My lock on light keeps flashing on my kenmore dishwasher?
Shorted control panel
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 14, 2014 | Kenmore Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Re-Set the control panel
if you are getting blinking lights on your console you may want to open up the door and visually look inside of the middle portion of your console and you'll observe an opening. this opening is where the latch and strike comes together to enaged power to the power board. you can take a butter knife and press the latch hooks downward. when you press the latch hooks(located on the latch then look at the front side of your console panel (at the same while holding the butter knife inside the latch keeping the latch hooks press down, press a wash cycle (normal, rinse, potspans, etc) and see if there is any more flashing. If not, then there is a bad connection with the latch.
Jun 07, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Maytag 24 in. MDBH955AW Built-in Dishwasher Logo
79 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
