Question about E-Machines eMachines Desktop PC
Bios check sum error
I changed the bios battery . Its not comming up. got check sum error..
    Master:
  • 569 Answers
There may be problem with *********** board get it repaired. there is also a chance of battery not working (even the new one)
Posted on Dec 18, 2008
BIOS CHECKSUM ERROR
Hello you just have to change the CMOS battery:
Press the lid to release the battery, and insert the new the same way.
The battery is a watch type CR 2032, and can be bought for a few bucks.
The batterys voltage is about 3 volts, when it looses it`s power, bios can`t remember it`s settings.
Change the battery, and setup the bios clock, date, bootsettings, and you are running again.
Take antistatic precautions when working on the mainboard.
Good luck
Jan 13, 2013 | Abit KT7E Motherboard
Drive A media error bios checksum error
your current bios is corrupted since the check-sum that was generated when your bios eprom was flashed with your current bios version doesn't match the check-sum that is generated as now, meaning that your bios changed for a few bits. you can fix this problem by re-flashing your bios with a good ROM file that you can download from your computer maker site or your motherboard bios maker site, also upgrading your bios with a newer version will take care of the issue as well.
Mar 07, 2011 | Computers & Internet
Error code reads "Cmos Check sum error-default
You need to fit a new bios battery a cr2032 normally
My tech team and I can help lots with PC stuff it would begreat if you could ask any PC questions you have here so we can guide youthrough it and discuss it properly http://www.mypcmates.com
Nov 05, 2010 | Biostar GEFORCE 6100-M9 Motherboard
Just bought this Samba 1845 system. Upon power on receive bios rom checksum error, insert system disk. Is the battery dead, bios need to be flashed again, please help
A BIOS sum check error is usually due to a near flat BIOS battery.
Replace the BIOS battery and configure the BIOS Date & Time setting etc.
Oct 27, 2009 | FIC Samba SM-1845 (SM1845GV) Barebone
Can nor remove bios password from a amilo laptop
Take out the battery for longer. It seemed to reset by indication of checksum error, but for an odd reason its still passworded. Remove battery and this time short the battery contacts on the motherboard and make sure no power or battery is in the machine. Then replace the battery and give it a shot.
May 06, 2009 | Fujitsu Siemens Computers & Internet
Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
Dec 18, 2008 | Computers & Internet
I am getting 1 long beep and then 6 short ones
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Dec 03, 2008 | MSI PM8M-V Motherboard
Check sum error denioted in win xp
you internal cmos battery is flat needs replacing. then reset time and etc in bios
Oct 10, 2008 | Televison & Video
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
