Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
T87 thermostat heat doesn't stay on long
My gas furnace is constantly turning on (2 minutes) and off. Is there some kind of setting (maybe the delay setting) that I need to change so that it will stay on longer.
This can't be good for my heating bill and I know it's not good for the comfort level in my home.
  • indy_deb Dec 19, 2008
    Appreciate your help. The way you described the location of the heat anticipator helped a great deal. Thanks so much for taking time to help me out with my heating. Happy holidays. d
  • Anonymous Mar 16, 2014
    I have a constant flashing code light. code on door panel says call for heat??
  • 24 Answers
Is this truly a T-87 round mechanical or is it the new electronic version? If it is gold in color it's the old tried and true, if it's white it could be either. Pull the outside ring straight out. If it is a t-87 mechanical you will see a mecury bulb setting on a spring on top. On the lower righ (4 to 5 o'clock) is a heat anticipater adjustment. Take the brass poiter and slide it to the left as far as it will go this should increase the duration of cyles and make them less frequent. This is if the problem is truly thermostat related. If it is the electronic version of the T-87 and it displays this behavior only when it is very cold out, it is a programming glitch that they were informed of 2 weeks after it came out, because I told them. If this is what you have purchase a new thermostat and replace that junk that is defacing your wall.
Posted on Dec 18, 2008
Gas does not ignite on furnace. Fan stays on even when shut off at thermostat. When trying to start, I hear a click and get a gas odor that stops quickly. Furnace had major overhaul 10 years ago.
You have a ignitor problem .Replace the ignitor .Is it a direct spark or a glow type .My guess it's a glow type .About the fan issue sometimes fan would stay running for maybe a minute even after you turn the fan mode ofg
May 27, 2017 | Heating & Cooling
Dual heat system, honeywell thermostat, auxiliary heat won't turn on
IT SOUNDS TO ME LIKE EITHER YOUR SYSTEMS LOW VOLTAGE WIRING IS INCORRECT, MOST LIKELY @ THE FURNACE. IT COULD ALSO SIMPLY BE THAT WHEN THE TECHNICIAN THAT INSTALLED THE T-STAT AT START-UP DID NOT GO THROUGH THE INSTALLER SET-UP & CHOOSE THE CORRECT SETTINGS FOR A DUEL FUEL SYSTEM. TRY THIS " SET THE THERMOSTAT TO EMERGENCY HEAT, WAIT A MINUTE OR TWO & SEE IF THAT TURNED GAS FURNACE ON. IF SO THEN IT'S A SIMPLE FIX IN THE WIRING OR PROGRAMMING & NOT SOMETHING MAJOR! GOOD LUCK!
Nov 25, 2012 | Honeywell VisionPRO Thermostat TH8110
The heat come on turn off but fan will not shout off.
if you have a gas or oil furnace then the limit control is probably bad. If you have electric heat or a heat pump then the sequencer is probably bad. But first make sure the thermostat is not set to "FAN". The thermostat must be set to "AUTO". Many systems have a time delay on the fan to capture the remaining heat after it completes a heating cycle. Usually several minutes.
Feb 17, 2011 | Heating & Cooling
My new honeywell T87N/T87K round is not turning on my heater
check for voltage then check connections sometimes the wire breaks and no power gets to the stat
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
I have a new York hybrid heat pump/gas furance
Did they check the sensor in the plenum. You are suppose to have bonnet sensor to switch from heat heat pump to gas whaen it is to cold for the heat pump. The bonnet sensor may be to bad. The unit is cycling ever five minutes because it may have five minute time delay.
Bryant programmable thermostat will switch on furnace
Turn the power off to the Air handler unit.
Remove the thermostat from the wall, (Just the face part).
Look on the back side of the thermostat and verify that the jumpers are set to electric and not gas, otherwise the fan will not run during heat mode, they come from the factory usually set for gas.
If this is a electric heater this will solve your problem, If it is gas then it will be more detailed. Once you put it back on keep in mind that most thermostats have a 3-5 minute delay so just give it a little time and the fan should then work once you have the jumpers in the correct position.
FlaTech
Thank you for using FixYa!
Nov 17, 2009 | Bryant Heating & Cooling
Thermostat T87
how old is unit? Sounds like it may be short cycling which could be do to it going off on limit.
Sep 15, 2017 | Honeywell CT87B ROUND HEATING&COOLING...
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
I've replaced my very old (mercury) Honeywell thermostat with a new one (round, Model: YCT87K1011), but I can't get it to control the temperature. If I connect the two wires one way, the furnace comes on...
Hey John, man that ole T87 has been around for a hundred years and I have installed many of them, but I cant remember the letters on the wiring. Seems to me that it is R-W-Y, any way you will use the R and W. I have a t87 at home still in the box and I could wait till I got home to help you but Im sure its the R and W terminal. Dont forget to set the heat anticipator. Set it the same as the current value of your gas or oil valve.
Nov 06, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
501 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
