Question about Denon DRA-275R
No sound from Denon DRA-275R
The screen is working, all buttons and switches too, but I don't hear "Click" sound from relay what applies power to output amplifiers when I start up the receiver. One of transistors C1841 in power amp is hot, but the transistor itself is OK and I found DC voltage (around 9V not stable)on 1 output from preamp BA!15218 (this IC is OK as well, I replaced it for the new one).
Could somebody give me advise?
Thanks a lot.
  • 4234 Answers
SOURCE: Denon AVR-3105 Unit tries to
Look for open resistors in the same area. Also, if the transistors that you replaced are the output transistors, you should replace their compliments as well. I don't have the service manual with me at the moment, so I'm juist giving you generalities. If you can, lift the center pin of the output transistors and measure (and post) the voltage readings on each of three pads for each transistor. That should give me enough info to guide you further.
Thanks,
Dan
Posted on Oct 07, 2008
SOURCE: Denon DRA-25/25L Stereo Receiver.
Without looking at the schematics for this particular model, I'd surmise that the click is indeed a speaker protection relay. Generally this is fed by a number of different sense circuits that watch for power amp issues and/or excess speaker current and/or power supply output stability. Although the relays do indeed fail at times, generally it is not the relay that is at fault. If you have a scope and a schematic, you can check the various circuits that feed the relay for the exact cause. If not, you can do some experiments that might help deduce the problem: e.g. do headphones work when speakers do not, does the relay click on when no speakers are connected (or selected), etc. In my experience, it is most often the output transistor(s) in the power amp. But not always ;-)
Posted on Oct 15, 2008
smarthome2
  • 1114 Answers
SOURCE: Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Posted on Jul 01, 2009
  • 336 Answers
SOURCE: exit transistor A1489 and C 3853 for a Denon Model
Goto www.mcmelectronics.com and search for 2SA1489 and 2SC3853
Posted on Dec 03, 2009
SOURCE: denon dra-95vr receiver has no sound out. All
Right on!
Jumpers was my problem. Luckily I had a pr. of short RCA's because my NAD jumpers were too small to reach across.
Posted on Feb 08, 2010
No power in receiver
If main fuse is blown then you have shorted output transistors
Mar 29, 2014 | Denon DRA-275R
Denon DRA-275R
Listen for a relay clicking inside. It you hear it but get no power, it is a problem with the relay. If there is no click, it is probably the power supply.
Aug 01, 2008 | Denon DRA-275R
How to connect speakers
Hello
Download the user manual to your set from internet. It have all the details.
Click here to downlaod it.
Apr 11, 2012 | Denon DRA-275R
When i search radio chanel with SCAN UP of DRA-275rd radio, he stop on a near frequency but not exact frequency, so i cant to tune in a station. could you help me please?
Check on the back of the unit for a switch marked "channel step" or something similar.Usually close to the anntena socket or connection.When you find it switch it to the alternative position.This should solve your problem.
Jun 18, 2011 | Denon DRA-275R
No sound to speakers with power on
OK. That tells me that the output section is good. This may sound silly, but check to be sure that the tape monitor switch is not on.
Dan
Jun 06, 2008 | Audio Players & Recorders
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
Denon DRA-275R Logo
249 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
