Question about SanDisk Sansa Clip MP3 Player
Did you get your fm tuner to work?
I am having the same problem and cannot figure it out. My music works fine, but my tuner went out. Any suggestions?
  • 8,596 Answers
Switch the USB Mode in your settings menu away from the mode it is in now, and try again.
Posted on Jan 01, 2009
How do I fix the FM tuner to pick up FM signals?
I think you might have fault in the FM tuner section. Most of these are done by a single IC, replacing that will cure the fault I suspect.
Jun 10, 2017 | Audio Players & Recorders
I can't get my tuner to work, but everything else works fine. All I get is static went I turn to the radio stations on both FM/AM
If you are in a fringe area you might need an external antenna to work with your tuner. Happens.
Oct 15, 2015 | Pioneer VSX-D704S Receiver
Onkyo T-4500 FM reception problem
I have the same tuner...yes the fm and am frequencies are different there than north america...check to see if you have the "worldwide" model...there is a small switch under a small hole underneath the tuner to select the region for where it is to be used. If its not the worldwide model then i think your outta luck.
Apr 21, 2010 | Onkyo T-4555 Tuner
Akai Stereo Tuner Amplifier(AA-1125).with faulty tuner
It could be that IC's that control the AM/FM radio have failed and need replacing. On the circuit diagram it has two numbered LA1240 and LA1230. Though it's unlikely both would fail at the same time. Unless you were not using the AM radio and that failed first and then the FM one went. However there is a 7 pin device which is called the Front End. This is located connected to the tuning gang. The metal thing with flanges that in-twine. Both the AM and FM aerial leads go into this before reaching the IC's. It contains a FET and some transistors. It has 12 volts on pin 4. And there is a 300ohm output on pin 3, where both FM and AM signals come out. So you can check that out. If it's not showing 12 volts on that pin there is something wrong or the 300 ohms on 3.
You could at one time get a replacement Front End, but after all this time it's unlikely they are still made. But with a lot of work it should be possible to get inside the Front End and replace the faulty parts.
The service manual is free and online. Just type the model number and service manual into google and you will see the free PDF of it. Parts numbers for the Front End are mentioned, just in case somebody still stocks it!
Jul 02, 2017 | Audio Players & Recorders
Will not tune any radio station, fm or am. everything else works fine. May be damage resulting from lightning, through the antena input.
It is very possible the fm tuner pack is damaged from lighting,if you have voltage going to the fm tuner pack im sure your tuner is bad pioneer part number for your tuner is AXQ7231
Sep 26, 2009 | Pioneer VSX-D811S Receiver
Philips SAA7130 TV Tuner/FM Radio/Video PCI remote stopped working
PLEASE THE SEND THE TV TUNER CARD DRIVERS I AM LOST THE TV TUNER CD
May 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Receiver went Tango Uniform
radio need tuner board assy.
Jul 16, 2008 | Dewalt DC011 AM/FM Radio
CD 's work fine - NO Am or FM
sounds like the aerial has fallen out the back.
Dec 12, 2007 | Sony CDX-FW700 CD Player
FM Tuner on my Digital Audio Player
Hold in the menu button ('M') for a few seconds and when you release it, you will be able to choose between your stored music, the radio, or system settings.
Apr 27, 2007 | Samsung YP-U2X Digital Media Player
SanDisk Sansa Clip MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
