Question about Canon imageRUNNER C3220 Color Copier
Canon IR 3220 Display panel won't go on
I'm working on a Canon 3220 - display panel doesn't go on. I got inside and noticed one of the cables (long, 2 prong female connector) is not connected. I can't located where the connection should go - any help?
    Problem Solver:
  • 12 Answers
Its not ur connecter, try ur power supply board
Posted on Dec 31, 2008
Canon ir 3300 display is not glowing .
my dear you chek cable wire display panel
Aug 24, 2015 | Canon Ir 3300 Black & White Copier
A restriction code
Hi. You can get the restriction code for a Nokia 3220 from
MobileUnlockSolutions.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 3220 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3220.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3220 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3220 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Jul 08, 2014 | Nokia 3220
Sharp ar-m700 no power
canon ir 3300 machion no display
Jul 15, 2013 | Sharp AR-M700U Grayscale Copier
Clc 3220 paper jam message
Is the display showing a jam in the fixing unit??? Did you l open and close all the doors & covers???? I have found that there is a plastic Exit flag on the small door that folds down on the fixing unit. It is plastic and it can break very easy. You may have to replace the flag. If you have another IR-C3220 try to switch the units with each other copier. The problem could also, be the black connector on the unit or in the copier, it may be broken... It is not easy to change the one inside the copier..... Good Luck
Jun 05, 2012 | Canon imageRUNNER C3200 Copier
Dell 6000 laptop screen blanks out - bought new screen
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Remove the hinge cover.
  3. Remove the keyboard.
  4. Open the display all the way (180 degrees) so that it lies flat against your work surface.
  5. Remove the four M2.5 x 5-mm screws (two on each side) that connect the display assembly to the computer.
  6. Loosen the screw that connects the grounding wire to the system board.
  7. Use the pull-tab to disconnect the display cable from the system board.
  8. If a wireless Mini PCI card is installed, disconnect the antenna cables from the card.
  9. Lift the display assembly from the computer.
Apr 06, 2009 | Dell Inspiron 6000 Notebook
Canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Feb 13, 2009 | Canon Office Equipment & Supplies
Cannon ir 6000 download mode problem
my copier not working only display the download mode.
Nov 18, 2008 | Canon imageRUNNER 8500 Copier
Canon Copier Key Panel Problem
Replace display touch control panel
Deshpande +919420906982
Oct 19, 2008 | Canon imageRUNNER 400S Copier
Canon iR 3220 printer problem with PDF files
Sound like a driver issue, reinstall and check that it is correct one.
Nov 09, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3220 Color Copier Logo
166 people viewed this question
old marine
old marine
