Question about Frigidaire FMV145K Microwave Oven
Everthing working with microwave except food is not heating
    President:
  • 2,992 Answers
This can be caused by a number of causes: a bad magnetron tube (which generates the microwaves), failed transformer or other power supply parts, bad control board or relay on it, bad door switch. Microwave servicing exposes hazardous voltages, and could lead to microwave leakage if repairs aren't done properly. Repairs should be handled by a professional.
Posted on Dec 18, 2008
How do i restart heating element in micro model GMH6185XVS-1
sounds like a bad magnetron tube... nearly as expensive to repair as to replace with a new microwave
Sep 14, 2014 | Microwave Ovens
Amana microwave
Remove the cover from the microwave. Where the door latches are you will find a couple small black switches. The buttons on the switches will be depressed when the door is closed. Check the switches to see if any are burned up or broken. They should have somewhat of a snap feeling when depressed with your fingers. If one is bad the machine will not heat. Replace the switch.
Dec 05, 2013 | Amana ACM1580 Convection Microwave Oven
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
GE microwave model JVM1750DM does everything except heat food. Worked this morning fine.
Chances are the magnetron has failed, "heats food" the other possibility is the high voltage capacitor and diode. Repairs will approach the cost of a new microwave oven.
Apr 19, 2011 | GE JVM1750DM Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. We used it about an...
Usually when it doesn't het there is a problem with either the magnetron or one of the power tranistors. You would have to get a shop to tell you what the problem is as it can be a few things. If you have warrenty either maytags or from the store just find out from the store/maytag where the repair depot is. They will either repair or replace it. If no warrenty then don;t do anything without getting an estimate. It may be just as cheap to buy a new microwave.
Aug 12, 2010 | Maytag MMC5000 Microwave Oven
Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
Everthing is working except food does not get warm
poss internal fuse between transformer and cap or maybe diode.
Sep 14, 2009 | Maytag Microwave Ovens
Microwave is not heating food
heatman101
fs
Mar 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Food not heating in microwave
Magnetron tube probably failed. Depends on how old the microwave is. If its still under warranty, call Frigidaire. If not, take it to a repair shop, get an estimate, and compare it to a new one. It'll probably be cheaper to buy a newer one that will have more power, but check anyway.
Dec 18, 2008 | Frigidaire FMV145K Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Frigidaire FMV145K Microwave Oven Logo
116 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
