Question about HP LaserJet 1300 Printer
HP 1300 makes noise and wrinkles paper
The printer makes a clicking noise when toner door is closed and while printing. Also the paper comes wrinkled in the upper left hand corner.
    Scholar:
  • 75 Answers
Open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Posted on Jan 07, 2009
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
When we print something,the paper comes out and is wrinkled and has some ink on it in places where there is no print. The fuser checks out fine.
Description sounds like the fuser rollers are bad.
To check it out run a 1/2 test.
Put paper in the manual feed tray. Print something. As the paper gets 1/2 way into the printer, open the top cover,(you might have to print a few sheets to catch it just right) take out the toner and look down at the paper. If it is wrinkled, you could have a bad toner cartridge. If it looks good...get the fuser replaced.
Jun 15, 2011 | HP LaserJet P3005n Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Paper wrinkles on one side when comes out of printer
hi i have printing problem when i was gave print after output on print right hand side in some lines in black form contiuos print on paper.
Jan 31, 2010 | HP LaserJet 1300 Printer
My printer wrinkled the paper when it is out
Try using fresh paper from a new ****. If still wrinkles might be an issue with your fuser. The fuser is the part that heats the toner onto the paper and if the paper contains too much moisture content (from improper storage methods), this can cause wrinkling effect as well.
Try printing with different types of paper and from manual tray to isolate problem. If it occurs all the time, most likely bad paper or bad fuser.
Jan 16, 2010 | HP LaserJet 4200 Printer
The paper wrinkles up while going through
This is possibly down to the upper fuser roller wearing and catching the paper when it goes through the fuser. The upper roller surface breaks up and splits
Oct 04, 2009 | HP LaserJet 1300 Printer
Wrinkling paper
You have a damaged fuser. Open the back door and look in the slot for the grey film sleeve. Your most likely going to see it torn or ripped up on the edge. If so you need a new fuser or to have your rebuilt.
Aug 31, 2008 | HP LaserJet 1300 Printer
Paper completely wrinkled
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
Jan 19, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
900 people viewed this question
Clive
Clive
