Question about Vats Passlock Passlock 2 Saturn Bypass
1996 caddy deville "theft system problem car may not start next time"
  • Stan Kline Dec 18, 2008
    I found a post that mentioned to put a resister in the orange wires from the steering to bypass the resister in the key. Has anyone accomplished this or have additional into. TIA Stan
  • Stan Kline Dec 19, 2008
    I shall have to look and see if the resistor is there. I've had the car for 10 years [pruchased used]. I shall buy a resistor that matches the key resistor in case the switch is really going bad. If it will not start I'll try the resistor before getting the car towed. Changed to a different key Thanks for the reply. I shall do nopthing rignt now.
My name is eric they call me e dog im one the best alarm installers around i dont get it right i dont eat i eat good give me a ring 815-601-5464
Posted on Sep 08, 2009
  • 27 Answers
Common problem. Ignore the lights unless the car really doesn't start.
Posted on Dec 18, 2008
  • Guy Dec 18, 2008
    The resistor bypass has probably already been done in this car. Thats probably why the light is coming on. That's why I said to leave it alone. If its not causing the car not to start why rock the boat?
    This is a common problem in those cars. Back yard mechanics and lazy installers cut the PATS wires and put a resistor inline to bypass the PATS anti theft system when installing a remote start. The correct way is to use a relay to switch to the resistor only while remote starting and back to the PATS system when starting with a key.
    Also, sometimes the connections on the switch will wear and the car won't read the resistance on the key. In this instance you can wire in the resistor to always bypass PATS. However, this will disable the factory security. The light on the dash will still work however, and may say "theft system problem." The car will still start because it is bypassed.
    Therefore, you can pick one or more of the following:
    1. Do nothing. Ignore the warning. (my suggestion)
    2. Replace the ignition switch, or clean the contacts in the switch. (may fix it, may not)
    3. Re-hook the PATS wires and take out the resistor bypass. (May fix it, may cause your car not
    to start,
    Guy
How do i reset the anti theft system on 1996 caddilac deville
There is no reset, it does this every time you lock and unlock the door or put the key in the ignition
Jul 27, 2012 | Cars & Trucks
Passkey problems
its the small chip in the key, after the resister goes bad it cant carry the proper amount of resistance to the anti theft system. you can easily bypass this problem and get the resistance reading with an ohm meter. after you get the correct reading you can purchase some resisters from an electronics specialty shop. radio shack used to carry them but have stopped carrying such items. after you get them youll usually have to connect 2 of them together with soldier and connecting them to the 2 small yellow wires on the security system (NOT THE BIGGER AIRBAG WIRES AS THEY ARE ALSO YELLOW) Once you do this your car will start up no problems at all. I am a certified caddy tech and have done this on many caddys so, i do know what im talking about.
Jan 13, 2012 | 1995 Cadillac DeVille
Car want start. anti-theft light light on
Check in the Cadillac-Deville-Owners-Manual (page 89 and next) details about THEFT System.
Hope helps.
Jun 02, 2010 | 1996 Cadillac DeVille
Car wont start ignishen disabled due to antitheft system
Get the system bypassed by an auto electrition.Then you want have an alarm.Or get a new alarm fitted
Jul 25, 2009 | 1995 Cadillac DeVille
1996 caddy deville
This sounds like an issue with the little chip on your key. My 96 DeVille periodiclly does the same thing. If you have problems with that chip you have to take it to a Cadillac dealership and have them look at the key. Should be cheap.
May 09, 2009 | 1996 Cadillac DeVille
I have a 97 caddy on dash a message enable to start due to auto
have you tried to get your key looked at??
maybe the resistor on it is no good anymore,
or maybe the wires for this system are damaged,
they are two skinny white wires inside an orange sleeve
(that's how it is on my 97 deville)
check under the dash.
May 07, 2009 | 1999 Cadillac DeVille
1996 cadillac deville anti theft system
TAKE ONE CADILLAC KEY PLACE IN IGNITION TAKE YOUR SPARE CADILLAC KEY GO UNDER NEATH YOUR DASH BOARD FIND THE ORANGE RUBBERY WIRE PEEL THE TWO WHITE WIRES AND PLACE ONE WIRE TO THE ONE SIDE OF THE KEY AND THE OTHER TO THE OTHERSIDE CRANK YOUR ENGINE AND IT WILL START YOUR CAR
Dec 24, 2008 | 1996 Cadillac DeVille
2002 Deville battery need replacing
IS IT NORMAL TO REPLACE CAMSHAFT SENSORS AND FRONT MOTOR MOUNT ON 48000 MILE 2002 CADDY DHS?????
Oct 20, 2008 | 2000 Cadillac DeVille
Theft car system
dear Hun~ It all has to do with the Vats system in your car. You can bypass it or get a new key or you might need a new ignition cylinder.
Sep 14, 2008 | 1997 Cadillac DeVille
Vats Passlock Passlock 2 Saturn Bypass Logo
263 people viewed this question
Top Stellar Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Stellar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
