Computers & Internet Logo
Posted on Dec 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you please tell me the steps to set up dial connetion throgh my landline telephone
Anonymous
Level 2:
  • Expert 38 Answers
  • Posted on Dec 18, 2008
Anonymous
Expert
Level 2:
Answers
38
Questions
Helped
9330
Points
108
Http://www.ehow.com/how_2057352_set-up-new-dialup-connection.html
Here is a step by step guide on how to set up a dial up internet connection.
Landline and internet not working
Follow the following steps:
1- Check your landline. If there is a tone signal or not. In case there is a signal go to step 2. In case no signal, contact your telecommunication company service center in order to repair your telephone line.
2- connect your telephone line to small device called filter signal. this device has one input (for telephone line) and two output line (one for your telephone system and other for ADSL your router)
3- You have to configure your router to connect to Internet.
For more details bout router configuration, contact me on [email protected]
I hope this help you.
My phone #1 does not ring nor can I get a dial tone.
Troubleshooting Home Phone for No Dial Tone ' iiHelp
https://iihelp.iinet.net.au/Troubleshooting_Home_Phone_for_No_Dial_T...
This article will explain what to do if you can't make or receive calls using your HomePhone (landline). ... If it rings normally, skip to step 3. If you hear an engaged tone ora recorded voice saying the number is not available, ... If you have a dial tone and can make a call when your phone is plugged into one socket but not ...
No Dial Tone - Phone Forum - Phone Forum - Cox Support Forumsforums.cox.com/forum_home/phone_forum/f/6/t/3496.aspxJan 1, 2014 - 16 posts - ‎13 authorsThis will help determine which phone or jack may be contributing to the problem. If these steps do not restore your phone service it may be necessary to ... directly to the #1 telephone port on the modem and see if you get dial tone there. ... Then try calling yourself(from a cell phone), and as it rings, plug the ...Big Mystery...Phone won't ring ' Techlore
I want to forward my home phone to my cell phone. Is that possible?
Assuming your telephone service provider offers the call forwarding service, yes. The procedure varies from company to company, but often you dial *72 from the landline, then the number to which you want the calls forwarded. That phone will then ring, and you must answer the call to confirm. To cancel the call forwarding, dial *73 from the landline.
If this doesn't work, contact your telephone service provider for their instructions regarding call forwarding.
2answers
Call forwarding
How does one forward incomming calls on a uniden 2.4ghz cordless phone?
Cordless phones can not 'forward' a call to an outside line.
Forwarding must be controlled by the ATT, Verizon, or landline provider.
Please contact your provider to determine if you have call forwarding feature built into your service package.
Then, follow the instructions of your landline phone provider.
Here is the instructions for Verizon:
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
  1. Lift your telephone's receiver and listen for a dial tone.
  2. Press star.gif7.gif2.gif.
    Dial 1172 on rotary or pulse-dialing phones.
  3. When you hear the tone, set or change the Call Forwarding number by dialing the telephone number where you want your calls transferred.
    You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
  4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
    You will hear two short tones telling you that Call Forwarding is activated.
  5. Hang up the receiver.
Feb 16, 2011 • Cell Phones
2helpful
Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
37helpful
3answers
My Panasonic Telephone Model KX-TSC35JXW dial pad is locked
I am having a Panasonic Telephone Model No.KX-TSC35JXW but I am not able to make calls because it is telling that the dial is locked but i dont know how to solve the problem.Please help me.
1helpful
Cannot receive faxes
Step one: Check the fax number
Make sure the fax number is correct; include any numbers that you have to dial to use the telephone, such as an area code, access codes for outside lines or long-distance services, and so on. If you have to dial a particular sequence of numbers to make a telephone call from that telephone line, you also have to dial that sequence of numbers to send a fax.
If the issue is resolved, you do not need to continue troubleshooting.
If the number is correct, continue to the next step.
Step two: Dial the number manually
Instead of using a speed dial setting or sending the fax from the computer, dial the number manually from the product control panel.
If the fax sends when you dial the number from the control panel, follow these steps to recreate the speed dial setting and insert pauses in the number.
On the product control panel, press the Setup button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Speed Dial Setup appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Individual Speed Dial appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) to select an unassigned speed dial entry, and then press the OK button.
Use the product keypad to enter any numbers that must be inserted before the fax number, such as an area code or access codes for outside lines or long-distance services, and then press the Redial/Pause button to insert a pause.
Enter the rest of the fax number, using the Redial/Pause button to insert pauses between the numbers, and then press the OK button.
Enter the name of the speed dial setting, and then press the OK button to save the speed dial setting.
Try to send the fax again.
If the issue is resolved , you do not need to continue troubleshooting.
If the issue is not resolved , continue to the next step.
Step three: Run a fax diagnostic test
Press the On button ( ) to turn on the product, and then make sure the product is correctly connected to the telephone jack.
Make sure that there is plain white paper in the input tray.
On the product control panel, press 6 , and then press 6 again.
This selects the Tools menu and then selects Run Fax Test .
The fax diagnostic test page prints.
Review the results of the test.
If the result of the fax diagnostic test is All Pass , skip to Step four: Reinitialize the fax.
If the result of the fax diagnostic test is a failure, a page prints that describes the issue and offers possible solutions. Follow the solutions on the printout.
If the solutions on the printout resolve the issue, you do not need to continue troubleshooting.
If the solutions on the printout do not resolve the issue, continue to the next step.
While the product is on, disconnect the power cord from the back of the product and from the electrical outlet.
Make sure that the telephone cord is fully inserted into the port labeled 1-Line on the back of the product.
Connect the power cord to the back of the product, and then connect the power cord to the electrical outlet.
When the product is in the ready state, try to send and receive a fax again.
Step five: Test the send/receive functions
Use the product keypad to send a fax. Watch the product control panel display and listen to the sounds the product makes.
If the product is working correctly, the following events occur.
When the product begins to dial, a dial tone is audible, followed by the sound of the product dialing. A Dialing message appears on the control panel display.
When the receiving fax answers the call, the product and the fax exchange tones. A Connecting message appears on the control panel display. During this phase, the product and the fax compare capabilities, exchange information about how to send the fax, and try to establish a reliable transmission speed.
After the connection is established, the product sends the pages of the document. Messages appear on the control panel display that indicate the status, such as Sending page 1 .
Review the results of the fax.
If the fax is transmitted successfully, continue to the next step.
If there is no audible dial tone or the receiving fax does not answer the call, try sending the fax to a different destination. If this second attempt also fails, continue to the next step.
If the receiving fax answers the call and begins beeping, but the Connecting message does not appear on the product control panel display, the product is not detecting the tones from the receiving fax. Continue to the next step.
Step six: Use an analog telephone service
HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service.
To obtain digital services information or support, contact the telephone service provider or system administrator.
Step seven: Check the phone cord and fax connections
Disconnect the telephone cord, and then examine the connector on the end of the cord. Make sure the cord only has two wires.
Figure 1: Telephone cord with two wires
Figure 2: Telephone cord with four wires
If the cord has four wires, replace it with a two-wire telephone cord.
If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
Make sure the fax is connected directly to the telephone jack by a telephone cord. Connect the cord to the 1-Line port on the back of the product.
Figure 3: Fax only
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
If other devices need to use the same telephone jack, make sure they are connected to the 2-Ext port on the back of the product.
Connect a single-line telephone to 2-Ext , and then pick up the receiver and listen for a dial tone. Make sure you are able to dial out using the telephone keypad. If you hear a dial tone and are able to dial out using the phone, the product is properly connected to a working telephone cord and telephone jack.
Figure 4: Fax and telephone
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - Telephone
Figure 5: Fax and PC or modem
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - PC or modem
If you change any cable connections, try sending and receiving a fax again to make sure that the issue is resolved.
Step eight: Remove any other devices from the telephone line
If any other devices, such as a telephone, an answering machine, or a modem, are connected to the telephone line, remove each device.
NOTE: Remove each device even if it is in another room, connected to another telephone jack, or connected using a line splitter.
Connect the product to an analog telephone line by connecting one end of the two-wire telephone cord directly to the telephone jack and then connecting the other end of the telephone cable directly to the 1-Line port on the back of the product.
Try to send a fax again.
Step nine: Perform a partial reset of the product
A partial reset of the product returns all fax settings to the default values. It might be necessary to reset the language and country/region settings after the partial reset is complete.
Disconnect the power cord from the back of the product.
Wait 20 seconds, and then press and hold # and 3 on the product control panel.
Connect the power cord to the back of the product, and then release the buttons when the product turns on.
The product is reset to factory defaults.
Try to send and receive faxes again. If the problem still exists, continue to the next step.
Step ten: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
3answers
V-tech 2498 landline phone with cordless
Tip 1 of 2 Recradle the handset for 15 seconds, then lift the handset and press PHONE. Tip 2 of 2 If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system: Step 1: Disconnect the power to the telephone base. Step 2: Disconnect the handset battery. Step 3: Wait a few minutes and then reconnect the power to the telephone base. Step 4: Reconnect the handset battery Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again. If that does not work, call the manufacture at 1-800-595-9511. Or take it back to where you purchased it and have then exchange it.
Grand Canyon Tech
Grand Canyon Tech
