Question about Samtron 76df 17" CRT Monitor
Widthless problem widthless display and excessive height found in monitor, but the variation ok through the micro switches operation.
0 characters
1 Points
Neovo f-419 menu keeps scrolling and will not stop
You have dust on the micro switches on the front.You can resolve this by flicking the buttons on the front, or you could take it apart and clean the switches with a spray cleaner like wd40 through them making sure you mop up all the excess.
Jul 13, 2013 | Neovo F-419 19" LCD Monitor
What is the parts of a monitor
Part Number:RK284AA#ABA
* Display Type LCD display / TFT active matrix
* Built-in Devices Microphone , Speakers
* Width 20.6 in
* Depth 11.4 in
* Height 18.9 in
* Weight 19.8 lbs
* Enclosure Color ( The image of the product displayed may be of a different color )
* Localization English / United States
* Display (projector) image aspect ratio 16:10
* Image Contrast Ratio 1000:1
* Diagonal Size 20 in - Widescreen
* Dot Pitch / Pixel Pitch 0.282 mm
* Max Resolution 1680 x 1050 / 60 Hz
* Max Sync Rate (V x H) 76 Hz x 82 KHz
* On-Screen Controls Switch video input , Brightness , Contrast , Image control , Color adjustment , Quick view , Language , Management , Information , Factory reset , Exit
* Controls / Adjustments Tilt
* Tilt Angle 30
* Signal Input VGA
* Digital Video Standard Digital Visual Interface (DVI)
* Type Microphone|Speakers
* Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
* Connections - DVI-Digitaligital , - VGA
* Microsoft Certifications Compatible with Windows 7
* Form Factor Internal
* Voltage Required AC 120/230 V
* Power Consumption Operational 65 Watt
* Power Consumption Stand by / Sleep 2 Watt
* Min operating temperature 41 °F
* Max operating temperature 95 °F
* Operating humidity range 20 - 80%
* Service & Support Limited warranty
* EPA Energy Star Compliant Yes
* EPEAT Compliant EPEAT Silver
Feb 15, 2010 | HP W2007 Desktop Monitor
Width variation is ok but width does not come to screen size, more than screen
you need to open up the OSD display on your monitor it is one of the buttons on the front. from there you can move to the width selection using the other buttons and then make alterations
If you found this information useful please click below
Aug 12, 2009 | Samsung Computer Monitors
Microphone does not seem to be working
The microphone connector is on the rear of the monitor, and you need to connect it to your computer's microphone input jack. The cable is the same kind you would use to connect the audio output jack to the input on a set of computer speakers. Once the microphone is plugged in it works just like any standard microphone. No special drivers are needed for the monitor, but you do need to be sure that the proper drivers for your computer's sound devices have been installed.
If this solution has been what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | Compaq Computer Monitors
I change the memory ic of lg 700e monitor the control pannel menu not displaying in english?
1. replace the control panel Micro switchs.
2. replace the 7805 reguletor near to control proccer.
Oct 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Dell E173FP 17" LCD Monitor
hi, check out the micro switches on the monitor.. let me know..
Nov 17, 2007 | Dell E173FP 17" LCD Monitor
Samtron 76df 17" CRT Monitor Logo
Top Samtron Computer Monitors Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer Monitor Expert? Answer questions, earn points and help others
