How to ajust free play at the steering system slight slight free play at steering wheel
No adjustment avail. Get someone to shake steering whils you look from under bonnet feel rack etc. I think you can replace the rack ends, (the arms that connect rack to track rod end)
I replaced my lower control arm and strut assemblies because my car was noisey over bumps in the road. Ball joints and tie rods are ok. The motor mounts look ok with the exception of the transmission mount which has some dry rotting cracks. I was wondering if the subframe bushings could be the problem. The car is 17 years old and I am suspecting them as the culprit. Sway bar bushings in the front are acceptalbe condition.
SOURCE: 1999 hyundai windscreen wiper arms have lots of free play
Usally the motor is under the bonnet and the arms are in the front air intake in front of the windshild. Sedans are difficult to get out and need to be timed when replaced. I hope this helps.
SOURCE: steering wheel goes back and forth from 11:00
do you mean your steering wheel turns when you are not moving the truck at all?
SOURCE: sloppy steering,play in steering wheel
Nort really, You have rack and pinion gear, Need to check tie rods, inner and outter, wheel bearings and any linkage in the front end first.
SOURCE: replaced steering box ,steering colium
you need to have alignment shop align front end . you can get close by adjusting tie-rods
SOURCE: 1990surf clutch wont return
the pedal freeplay should be about a quarter of an inch. This is the area the pedal travels before the first amount of pressure is applied. have you checked your clutch fluid? if its low you should scope for leaks, check the master cylinder and slave cylinder, pull back the rubber boot and check for any fluids. i would do this only if the fluid is low. have you had any clutch work done recently?
