Question about Panasonic Panafax UF-550 Plain Paper Laser Fax
Transform the fax from pulse to tone
Hello I want to transform my fax from pulse to tone because it's making me problems when dialing. Thanks and regards. Layal
  • Layal Hage Mar 28, 2007
    The model is : PANAFAX - UF550
  • Layal Hage Mar 29, 2007
    I solved the problem.
    Actually i enterred to the parameters (Set parameters) and i fixed it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
ALTERNATIVELY FOR IMMEDIATE SOLUTION DIAL FIRST STAR(*) BUTTON AND DIAL . HAPPY FAXING OMNIPRESENT
Posted on Sep 23, 2007
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
I have a Brother mfc 290c. My problem is it won't send faxes, it keeps saying "no response, busy" I have a duet line. I have tried every combination in the book but still can't seem to find the solutions...
If you get the "busy/no response" message it is because the fax machine does not get a response when it tries to dial out.
Make sure you have a dial tone by pressing the "hook" button. If you do not have a dial tone, make sure the phone line is connected to LINE on the machine.
If you have a dial tone, try dialing the fax number. If you hear a recording, there is a problem with the line.
One of these two possibilities is causing the problem.
Thanks,
Pat
May 12, 2010 | Brother Office Equipment & Supplies
HP 7680 Fax paper will not go through
Have you checked that you can get a dial tone?
Can you recieve fax's?.
If no dial tone then check that you have the telephone cord plugged into the line jack on the back of the fax machine and not the tel or ext sockets.May be a telstra problem so plug another phone into the wall socket to see if you can dial out.
Also make sure that the fax is set to pulse dialing.
Oct 25, 2009 | HP Office Equipment & Supplies
Multifunction phone/fax/copier machine
Hi sythonk
1. Make sure you have a telephone cable connected the jack labelled "LINE" on your brother machine.
Go through the Menu on the LCD, Initial setup, dial tone, choose the correct dial tone PULSE or TONE.
Exit from the menu.
Pick up the handset on the fax machine, and dial your nuber to make a phone call. (To send a fax, dial the number without lifting the handset.)
Hope this will work for you. If it solved your problem, give a please rating
Cheers
luciana44
Sep 06, 2009 | Brother Office Equipment & Supplies
No matter what number i fax to I always receive a fax busy message. I have tried different phone jacks throughtout the house. What can I do to correct this problem? Thanks in advance!
Check in the fax setup menu and make sure that the setting for tone or pulse is set correctly for your area, most all systems now are set for tone dialing. Make sure you input the number just as you would dial it, like 1 before the area code and no area code if you are faxing a local number...
Aug 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
Customer looking for pulse fax machine in remote area
Most fax machines will work either way, but you have to set it that way thru the fax settings or it will not work correctly.
Andrew
Mar 16, 2009 | Office Equipment & Supplies
Faxing on pulse line Brother Fax-575
HELLO! YOU WILL NEED TO GO INTO THE SET OF THE MACHINE, THERE IS SECTION THAT WILL ASK YOU PULSE OR TONE PUSH TONE THEN THE SET BUTTON GOOD LUCK
Feb 01, 2009 | Brother FAX-575 Plain Paper Thermal
SF-515 does not dial anymore
Hi there try this press menu then using the arrow keys go into machine settings I think if not you are looking for line type. Once in the make sure it is set to tone.
Once you have done this come out and try if this doesn't work then the control panel maybe faulty and you could take it apart and clean the number pad keys and make sure that the buttons move freely.
If they do cleanup and put back together and check machine if it still doesn't work then the panel will more than likely need replacing.
Thanks J
Nov 14, 2007 | Samsung SF-515 Plain Paper Laser Fax
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Panasonic Panafax UF-550 Plain Paper Laser Fax Logo
74 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
