Question about Tally Matrix T2280 Printer
Printer not saving changes made to the menu cpi option.
Evry time i try to change the cpi option from 10 dpi to 20 it works for a while and later reverts back to 10dpi printer the character very large other changes i have made are ok but this just would not be stable.
2 Suggested Answers
  • 186 Answers
SOURCE: t8006
There definitely must be a setting to reset the fuser counter. I cant tell you where to look as I am not familiar enough with that model. Check in the counter menus or the maintenance menus, or a reset menu.
Posted on Jun 22, 2007
At times while printing reports, the printer will continue printing off the page
LM=1 is left margin, RM=220 is right margin, TM=2 is top margin, BM=64 is bottom margin, FL=66 is form length (66 lines is 11 inches when LPI=6 lines per inch) PRTFEA=H means you have the print feature dial set to Host. Change the dial and you get different settings for forms, checks, invoices, reports. A-F.
Perf Skip just skips over the perforation where the pages are perferated. Enhanced means its double strike vs Draft mode.
These settings tell me you are printing compressed print (CPI=16) on wide paper (green bar) cuz RM=220 right margin is 220. For 8.5x11 paper 132 is the correct margin with at 16cpi. or 80 for 10cpi. Clearly you have the wrong paper in here if you print off the page. You must have 8.5 x 11 or 11 x 8.5.
Host allows the computer to change the settings on the fly. That may be why it goes off the page later. (Or it could be a carriage jam that makes it think its at space 1 when it isn't.)
I don't know what you are trying to print so I can't help you. I can tell you that having right margin on 220 is why its printing off the page.
You can change the dial to preset draft 16 and print a menu for those setting or you can change the RM to 132 or 80 by using the command, menu, change and accept keys.
Its been 10 years or so for me but take the printer off line by pushing the on-line button, press command, press menu and it will print all the settings like you have done. It will then print whatever the first item you can change is, press accept and keep accepting until you get to RM=220 then press change. It should print 80 or some number, press change until you get to 132 then press accept. Press accept until you get to the end. Press Normal and on line.
If you change the print size from 16 to 12, or 10 you will need to change the RM to the correct width.
Can't find a manual online for you. I probably thru away 200 of them in 2007 when PCS closed. It would show you what the choices are for each setting. And what the preset and A-F settings are without printing a menu on each one.
ftp://ps-2.kev009.com/incoming/jim/TSSPRT/acroread/tssfact/tfsprt/ti/tfsti001.pdf
You might can buy a manual from Dennis or Rick...
https://www.fastprinters.com/ProductDetails.asp?product_id=TI-880DP
Are you a Auto or Ag Equipment dealer?
Jun 03, 2014 | Texas Instruments TI 880 Matrix Printer
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
How do I change the Optical resolution on lexmark 2600 to 300 dpi ?
On your computer, go to Start menu > All Programs > Lexmark X2600 Series > Lexmark Productivity Studio. Select 300 dpi for your scan setting. Save the new setting. Then, try to scan a document to verify that the new setting has taken effect.
Sep 09, 2011 | Lexmark X2600 InkJet Printer
Dell 1320c is giving faded printing in both color and black. I've replaced two toner cartridges, tried to 'bleed' the cartirdge by printing 20 copies, toner save is turned off and there is no...
After you click print, and just before you print, go to your 'printing preferences' or 'print settings' in the popup window. From there, cycle through the tabs, and ensure that 'print quality' is NOT at draft and IS on normal or high quality. Alternatively, you change the 'print resolution' in this window, if the option is available. Resolution is usually given in 'dpi' so choose the highest 'dpi' value. This should hopefully give you darker prints
Aug 26, 2011 | Dell 1320c Laser Printer
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
My Printronix P5005 is having problem in printing setting. it prints out of paper. i want to adjust its printer setting. please guide me how i can change printer setting. thanks Tahir
tell me its graphics printing or plain Text... if plain text then change CPI like 15Cpi / 17.1Cpi / 20Cpi/ and also change Ignore CPI in Hosts menu...for graphics u can;t do anythigns..
Jan 27, 2011 | Printronix Line Matrix P5005B Printer
How to set it 20 characters per inch
Where do you want to set the font?
Do you want the font as the default font on the printer or do you want the application to call the font?
Application wise, to get a 20 cpi character font, you need to place the font change into the document.
Remember, even if you set the default font as a 20 cpi, if the application calls for a 10 cpi font like Courier, the printer will change the default font to the 10 cpi font for the life of the current print job unless there are additional font calls within the print job.
The software (Application always overcomes default settings)
Don
Feb 15, 2010 | Panasonic KX-P3626 Matrix Printer
Scanned files are too big
Change the file format its saving in. different formats have different compression rations. Jpg images are smaller than bmp images. simply by changing it to jpg it will be 20 times smaller. To do this when click save and the save image box appers, in the format type select jpg or gif or what ever is avilable. Play around to see what gives you the smallest size. You can also use software like Photoshop, paint, and other image editors to change the format its being saved in.
Dec 16, 2008 | HP LaserJet 3380 All-In-One Printer
Lexmark T642 Missing Character
change font size CPI from 10 to 15
Jul 04, 2008 | Lexmark T642 Laser Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
Tally Matrix T2280 Printer Logo
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
