Question about Canon PIXMA MP760 All-In-One InkJet Printer
Printer trouble My Red alarm light is flashing on my printer with a message error turn the machine off and on have done this and waited about 15 minutes turned it back on still flashing also said have done this tried a few things from that not a lot there on this one or I couldnt find it still flashing can you help THANKING YOU Robert
  • lexjen Feb 23, 2009
    On Canon Pixma MP760, keep getting alarm "Error. Turn the machine off and on. (See Manual). Have tried all the suggestions, removing USB, turning off Power, moving the cartridge carriage etc.etc. keep comming up with same error message. Just about ready to through it out and start again. Can anyone advise???
I also have the same problem after checking the Canon web site I found a page which deals with this problem By:
1.) Press the "Of" button to power down the Printer
2.) Remove USB cable.
3.) Remove Power cable.
4.) Waite 3-5 Minutes.
5.) Re-connect USB cable.
6.) Re-cone ct Power cable.
7.) Press "On" Button.
And all should be seet, not in  my case the blasted
red alarm is on and the error message returns again.
Anybody knows how to fix this blusted problem???
Bill Slow
Posted on Oct 17, 2007
  • Bill Slow Oct 19, 2007
    Hi Robert!
    Have fixed my red light problem, opened the Printer Cover and the two doors to get to the print head as I noticed that the machine on start up
    wanted to move the head but could not and this caused the red light to come on.
    I pulled the print head to the left to have a look if any dried ink would be the cause of sticking but could not see any but I noticed the two foam ink-pads which collect the ink when the head is being cleaned I checked with a cotton tip how dry the pads where and lo and behold the cleaning
    mechanism popped down, it must have been stuck in the up position and
    ergo caused the Red Alarm light to come on, and no unplugging of the cables and restarting would have fixed this.
    Anyhow I moved the head to the right again and started the printer, after the head reset it self to the right position it started a cleaning process and the red light disappeared, I did a test print and re-alignment test and all is now sweet again.
    Good luck
    Bill Slow
THANK YOU, THANK YOU, THANK YOU!!!! My Printer foam pads were also in the up position. This was the second time with this problem but I jagged it with a turn on and off the first time. This time that didn't work to a HUGE THANK YOU!!!!!
Posted on May 05, 2009
Bill slow's solution just worked perfectly for me and saved me a lot of money! Cheers Bill!
Posted on Jun 30, 2010
As per Bill Slow's suggestion I played around with the ink pads. Not sure exactly what I touched but they popped up. I think I was around some little plastic flaps at the front of the pads.
I manually moved the print head a little, shut the printer and re-powered it.
It reported foreign material in way of print head. So I opened and moved it again, closed it up and again re-powered it.
I did notice when I re-opened it the pads werre back down so I think it was the same problem that Bill reported.
Seems to be working fine now.
Note I did get ink on my fingers during the exercise. A bit of washing powder has cleaned them up. Funny that it dries everywhere else but on the pads!
Regards...Len
Posted on Jul 11, 2008
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Ink tank errors have occurred
  1. Turn off the printer
  2. Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  3. Hold the Power Button, release the Resume Button.
  4. Not releasing the Power Button, double click “Resume” and release Both Buttons.
  5. Click “Resume” for Four times
  6. Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
Jul 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Alarm light flashing, please wait message
Can only try
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
540 people viewed this question
old marine
old marine
