Question about Denon SC-M201 Main / Stereo Speaker
Securing the speakers to the stainless steel stands
The stick on velcro pads on top of the stands, supplied to support the speakers keep detaching from the speakers. Can the base of the speaker cabinets be screwed to the stands?
The speakers are Denon SC-M201
SOURCE: How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Posted on Oct 17, 2007
  • 151 Answers
SOURCE: How do I hook up my 2 outdoor speakers to a Denon 3805.....P.S no remote
PUT YOUR OUTDOOR SPEAKERS INTO SURROUND BACK SPEAKER "PORTS"AS YOU CALL THEM GEMMEG THEN GO TO UR SET UP MENU AND SWITCH ON ZONE 2 OR IT MAY BE AS SIMPLE AS A SWITCH ON THE FRONT OF YOUR AMP.IFF YOU STILL HAVE NO SOUND YOU MAY HAVE 2 TURN THE VOLUME UP FOR ZONE 2.ALSO SOME AMP NEED TO HAVE THE SOURCE ; IE WHAT U WANT 2 PLAY INTO ZONE 2 FOR EXAMPLE YOUR CD PLAYER.HOPE THIS HELPS ,IFF NOT GET BACK 2 ME 2 C IFF I CAN DO ANYTHING ELSE.
Posted on May 20, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR 1603 goes to stand by mode
It has a blown channel, unless you are good at repairing them I suggest an authorized Denon service center. This Denon not only needs the shorted output transistors replaced, but a few resistors, a couple of driver transistors and a capacitor on the preamp board as well. alot of parts to be replaced. I have repaired about a hundred of these over the last few years and my shop charges about $200 for this repair, other shops should be about the same.
Posted on Jun 17, 2008
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Posted on Nov 06, 2008
Remove discoloration from my stainless steel refridgerator
Use this suggestion with caution. Assuming it is real stainless steel (not a coated or faux finish) and you have already tried various cleaners without success.
Purchase Scotch-Brite pads for stainless steel (many automotive stores sell them for a few bucks) and lightly rub the area beng careful to ALWAYS RUB/POLISH IN A STRAIGHT LINE WITH THE "GRAIN" or brush marks to polish out the stain. Always test this on an inconspicuous area first. This also works well with stainless steel vent hoods and cook tops.
Sep 11, 2014 | Refrigerators
Tip
DISSEMBLING AND POWER SUPPLY CIRCUIT
1. REMOVING OF REAR CABINET
1. Remove the 11 screws [1], 3 screws [2] and detach the Rear Cabinet.
2. REMOVING OF CONNECTORS, SPEAKERS, STAND COVER ASSEMBLY AND STAND ASSEMBLY
1. Remove all the connectors from all the PWBs.
2. Remove 2 screws [1] and detach the Speaker-L and Speaker-R.
3. Remove the 2 screws [2], 4 screws [3] and detach the Stand Cover assembly.
4. Remove the 4 screws [4] and detach the Stand assembly
3. REMOVING OF PWB UNITS
1. Remove the 1 screw [1] and detach the R/C, LED PWB Unit.
2. Remove the 6 screws [2] and detach the MAIN PWB Unit.
3. Remove the 4 screws [3] and detach the POWER PWB Unit.
4. Remove the 4 screws [4] and detach the INVERTER PWB Unit.
5. Remove the 1 screw [5] and detach the KEY PWB Unit..............CHECK THE LINK FOR MORE INFORMATION
Electronics Equipment Repair Center
on Feb 14, 2015 | Sanyo Televison & Video
Velcro pad that the sandpaper is fixed to has come off the plate. What's the best glue to use to re-stick the pad with?
You may try a two part epoxy, or gorilla glue. Let dry for a day or two. Sometimes 3m spray adhesive also works. Let tack before sticking together though.
Oct 19, 2012 | Dewalt DW 411 HAND PALM SANDER
Sanding disk will not stick to the disk pad
IF you have a new disk and it will not stick, the velcro-like surface on the machine is worn. "Hook and Loop" is but another term for "Velcro" and the simplest solution is to purchase velcro tape from any fabric store and glue the correct side to the sander.
Aug 15, 2011 | Porter Cable 343K 5" Random Orbit Sander...
How do I access gears in a200 hobart. I don't see any screws to detach top. top looks painted shut.
There are two screws holding an access cover on the top front half of the mixer. These screws are normally plainly visible - has it been repainted heavily enough to hide the screws?
If you can't see the screws, all I can say is they are there, under the paint. Maybe shine a flashlight accross the top front half at an angle and look for a hint of a slotted screw head in the paint.
I'm not sure what the access cover is made of nor am I certain if the screws are stainless steel, but if the cover is aluminum and the screws aren't stainless steel, then a magnet should be able to locate the screws for you.
The screws a usually a domed-flathead screw, so some very close inspection of the paint surface may show a slight "bump" where the srews are.
Nov 14, 2010 | Hobart A200 Stand Mixer
NEED NEW VELCRO DISC PAD SANDING DISC WAN`T STICK
http://www.hitachi-powertools.co.uk/locator.html
This will take you to the UK dealer locator. If you are outside the UK you will find tabs at the top of the page to direct oyu to other regional sites.
Jun 13, 2010 | Hitachi SV13YB 5" Random Orbit Finishing...
How to remove scratches from stainless steel appliances
Try this at your own risk. Step 1 Consider using a product made for stainless steel2_bing.gif such as Scratch-B-Gone or Bar Keepers Friend (see Tips).
  • Step 2 Or, try spraying an all-purpose cleaner (such as Formula 4092_bing.gif) on the scratches.
  • Step 3 Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
  • Step 4 Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
  • Step 5 Rinse the surface and wipe dry.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Tips & Warnings
    • Before using any treatment on your stainless cookware, sink or appliances, it is wise to call the manufacturer for advice.
    • A new product called Scratch-B-Gone is touted as the "first aid kit for stainless steel." You can find it at many home improvement stores.
    • Bar Keepers Friend is another product for stainless steel. It can be found in most grocery or home improvement stores, or at www.barkeepersfriend.com.
    • To keep stainless steel sinks from scratching, put a rubber mat in the bottom of the sink to protect it.
    • Avoid using abrasive
    Please rate 4 thumbs for the free answer
    Mar 13, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    I can't get the velcro pads to stick to my Ryobi RS280VS sander
    Sounds like it is time for a new backing pad. Usually the hooks get cooked and/or caked so that they don't have the "claws" to grab the fuzz on the sandpaper. If this is a well used backing pad, the hooks eventually just break off from heat and wear.
    Nov 28, 2009 | Ryobi Tools & Hardware - Others
    Maytag MFI2568AES Stainless Steel Bottom
    perhaps there is ice holding it in because that tab is all that holds it.
    Sep 29, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
    Bosch built under oven
    you can try high-temp gasket maker from an auto supply store.
    Jun 04, 2007 | Bosch HBL 745 Stainless Steel Electric...
    Denon SC-M201 Main / Stereo Speaker Logo
    Top Denon Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
