Question about Dell Latitude C400 Notebook
Computer says no hard drive at boot up
I got a screen that said, my computer had to do a "virtual memory dump" now its says, "no hard drive found" at start up. now what?
    Scholar:
  • 86 Answers
Go into the BIOS and see if you can Auto Detect your drive... If not, check the jumpers on all your devices and set them to Cable Select. See if the Disk inside of your HD is spinning up and if it is then thats a good sign... You can boot up a Linux Live CD like Ubuntu 8.10 and check to see if you can access your drive and recover the data. Hopefully the disks spin and your control board isn't fubar...
Posted on Dec 18, 2008
Not enough virtual memory
Step 1:
Virtual memory is a portion of your hard drive that Windows sets aside to utilize as memory. When your RAM is over utilized, the operating system can swap pages of data to the hard drive to make more room. Swapping files, or paging, is slow, but it allows your computer to remain functional when your memory space is full. If your virtual memory space, or page file, fills up as well, you'll get an error. Fixing this issue is quick and the process is identical in safe mode or in a typical boot situation.
Change Virtual Memory Settings in Windows XP Click "Start" from the Windows desktop. Right-click "My Computer" and click "Properties." Select the "Advanced" tab and under Performance click "Settings." Select the "Advanced" tab and click "Change" under Virtual Memory. Click "System managed " to allow Windows to automatically adjust your Virtual Memory as needed. Click "Custom " to alter the memory space to your own specifications. Enter a value in MB equal to at least 1.5 times the of your computer's memory for the initial . Enter a value in MB no larger than four times your memory for maximum . Click "OK" and restart your computer for the changes to take effect.
Feb 13, 2013 | Microsoft Windows XP Professional
Dell Vostro 1500 Laptop: Without any obvious warning, my laptop will no longer boot into windows vista beyond the "microsoft corporation" screen with the green progress bar. it will get past the...
@rkbrown1_rb
If your Dell diagnostics shows no fault on the hardware (hdd, memory, chipset, videocard, etc.) but still same issue occurs, I recommend doing another test using a different utility. Try using Hiren's Boot CD that can be found here and try running the S&M Stress Test 1.9.1 and Video Memory Stress Test 1.7.116. If your computer hangs while doing the stress tests, the video card or CPU might be failing already.
Good Luck.
Sep 05, 2011 | Dell Vostro 1500 Notebook
My hard drive never stops
Windows is probably constantly trying to create virtual memory using the hard drive's free space. Buy more RAM and/or create a larger virtual memory file. If it's Windows XP, try right-clicking on My Computer, Properties, Advanced, Performance, Advanced again, Change (under Virtual Memory), increase the Initial Size to AT LEAST what is "recommended" lower down on that screen but no more than 1 1/2 times the actual physical RAM, then click Set.
Jan 01, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Blue screen on start up
This may be related to faulty memory or your page file (virtual memory) may be damaged.
You can try to remove your ram chips one at a time (boot up) and see if one is bad or make sure your virtual member is set to system managed.
To change your VM settings follow these steps:
  1. Click Start, right-click My Computer, and then click Properties.
  2. Click the Advanced tab.
  3. Under Performance, click Settings.
  4. Click the Advanced tab.
  5. Under Virtual Memory, click Change.
  6. Click No paging file. Click OK, click OK, and then click OK.
  7. Restart your computer.
  8. Click Start, right-click My Computer, and then click Properties.
  9. Click the Advanced tab.
  10. Under Performance, click Settings.
  11. Click the Advanced tab.
  12. Under Virtual Memory, click Change.
  13. Click System managed sized. Click OK, click OK, and then click OK.
Apr 27, 2009 | Computers & Internet
My HP Pavilion laptop will not boot.
Usually the message about low virtual memory is because there isn't enough RAM and it was using up all the designated space on the hard drive as Virtual memory. (Uses a part of the hard drive like RAM)
That shouldn't account for being unable to boot into any Windows options though.
The one trick with HP computers, you can try is to take the battery out, make sure the Laptop isn't plugged in with an AC adapter then press and hold the power button in for 10 seconds with no power going to the laptop. This is doing a power drain. Then put the battery back in and try to power on and boot up the computer.
When you choose safe mode, does the computer ask which operating system you want to boot into and does it give you the option to choose "Recovery Console"? Or is there an option on the screen with the safe mode options to Choose your Operating System? If not then the recovery console wasn't installed. If you can choose the recovery console, you might be able to replace the failed files that are not allowing the computer to boot into any version of Windows. Unfortunately, the computer isn't reporting which files are the problem, winlogon.exe/userinit.exe/etc.
You can get a hardrive enclosure at a computer store that allows you to put the laptop hard drive in the enclosure, then plug the enclosure into another computer with a USB cable then you can copy the sensitive data onto the other computer.
If you aren't comfortable taking the Hard Drive out yourself, you can take the laptop to a computer store, and they will take the Hard Drive and hook it up to a second computer as a Slave (Secondary Hard Drive) and copy the data over for you
Apr 12, 2009 | HP Pavilion dv8000z Notebook
Slow
Hi Whose,
Me again :-)
Yes m8, there is something you can do.
Perform the steps given below to increase your system performance.
Uninstall all unwanted software:
To uninstall software
Click on Start
à Settings à Control Panel à Add/Remove Programs
Select the software (one at the time) from the list and click on the Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temp folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag.
You should defrag every hard disk on your system.
This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Dec 11, 2008 | HP Compaq nx6110 PC Laptop
Computer is slowing down
Hi Big Bad Bob, and welcome to FixYa,
you computer is "dirty", clean, and feel the difference:
Click on Start
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
regards
Yeis the Wiz -> vote :-)
Dec 06, 2008 | Computers & Internet
My C:\drive is full and i have removed files to make space but it stil says there is not enough space on drive. What can i do?
Copy this text into a word document, print it and have it next to you when you ferform this:
Perform the steps given below to increase you system performance and clear space.
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Nov 30, 2008 | Acer Computers & Internet
My computer needs a clean out.
Perform the steps given below to increase you system performance.
Uninstall all unwanted software.
To uninstall software:
Erase unnecessary files in the windows temporary folder.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag. You should defrag every hard disk on your system. This process can take quite some time.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Nov 29, 2008 | Computers & Internet
Gateway mx6930 laptop freezes up every 10 minutes - keyboard and mouse become inoperable
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Dell Latitude C400 Notebook Logo
73 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
