Question about Samsung Computers & Internet
17" color monitor is not powering up.
Power cord, Fuse and Switch are good.
  • Tyrone Martinez May 11, 2010
    CRT or LCD? if it's CRT i would just go and buy a new monitor.
  • 153 Answers
Check the power regulator transistor and the transistors at the horizontal out setion.
Posted on Dec 19, 2008
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
We had a power outage at my shop and now my Dell e171fp monitor will not power up. No light near on button and monitor is black. Switched to known good pwr cable and monitor still blank.
This generally is not good news, when the power comes back on it peaks causing the damage in it's wake. The power supply has been compromised and if you are very lucky you might get away with a fuse change. The monitor will need to be dis-assembled to assess the situation and hopefully it will start back up with minimal repairs. The fuse should be located near the power cord going into the circuit board.
Feb 28, 2011 | Dell E171FP 17" Flat Panel LCD Monitor
I have starlogic 17' monitor it just stopped working no power at all no lights ,,,nothing
Check the power cord, make sure it is firmly connected to the mains outlet and in the monitor. The power cord maybe faulty. try a different power cord,
If this doesn't work then the fault is in the monitor, most likely the power supply circuit.
I don't know this make and model, but it may have a blown fuse. If you are not an electronic savy person, I would advise you NOT to try to fix this problem, as there dangerous voltages in the monitor.
The cost of a repair maybe too high, I suggest you put your money towards a new LCD monitor.
Nov 15, 2009 | Star Logic 17" LCD Monitor
I have no power to my HP vs 17e. It appears that
This is a powerboard problem,look for bad caps(blowing up)
look at my profile to find a solution and the pictures for the HP version.
Jun 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
No power
Could be the power supply like you said and the most obvious things to check when its open is the small fuse on the power supply or any capacitors which are buldging which are faulty.
This is for lcd monitors which have a built in power supply or if you dont know they use the kettle type lead =].
Feb 11, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Hp monitor 18" LCD color d5063
Turn the monitor upside down and turn on the lights in the room.
Then you will see a location for a power cord, remember three wires/prongs. Good luck.
Jun 21, 2008 | HP Pavilion F1703 17" LCD Monitor
L17T
If you can open the cover of your monitor try to locate the fuse maybe the fuse is busted replace it.
if the fuse is blown or busted again there is short circuit in your power supply maybe the diode or the power transistor is shorted you need this to bring to the shop for services
Apr 15, 2008 | Hyundai ImageQuest L17T 17" LCD Monitor
Doesn't work
First you check power cord by multimeter for ok .if it is ok then open the monitor and check fuse in power section.If it is ok then check pf in power section.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 21, 2008 | Advueu Technology ADV178T 17" Flat Panel...
Computers & Internet Logo
71 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
