Question about Kenmore 98702 Stacked Washer/Dryer
HOW TO REPLACE THE COILS
TAKES FOREVER TO DRY I THINK IT NEEDS NEW COILS SO HOW DO YOU REPLACE THE COILS. HOW TO TAKE IT APART ETC.
THANKS
PAT
  • gervaispa Dec 18, 2008
    THANKS I'LL WORK ON IT AND LET YOU KNOW. BUT ITS GOING TO TAKE ME A WHILE
  • Kenmore Master
  • 8,220 Answers
It has been a while since I fixed one but I think you have to get the top off first. Then you can get the front off. Then go trough the back hatch and get the belt loose from the idler. Then remove the drum. It is a piece of cake after that. Clean it up good and check the blower wheel for looseness. Those coils you speak of are very easy to swap out, No way to get the 2 hooked up wrong.
Posted on Dec 18, 2008
How do i fix dryer taking long time to dry
BAD HEATING ELEMENT. I believe that particular model has a ring type heater coil; very effective but fragile. The dryer must be disassembled until you see the entire heater coil, I've attached a photo. The replacement is less than $80 via Amazon Prime, I know, I've done this. The kicker is that the coil was still putting out a little heat but taking forever to dry. You're just asking for a fire or a total breakdown which could adversely affect your control board (not cheap). Hope this helps. 5307dbc3-6273-485b-aaec-414a05b9c79c.jpg
Jul 13, 2014 | Frigidaire FAQE7001LW Affinity 7.0 Cu. Ft....
A,S,D,Q,W,E keys not working.
You can repair any keyboard problems by taking it apart. Find the plastic mats with the exposed electrical contacts and look for food dirt, sugar syrups etc. Using a little water and a toothbrush clean and rinse the food covered areas and pat dry. Leave it to dry for an hour. Try putting it back together and see if it works. If not.... then take the offending letters and look for where the carbon paint touches those contacts and either repaint with carbon paint (available from a quality electronic supply) or just use crazy glue gel and glue little foil pieces to each carbon painted spot that is acting up. This works for remote controls too.
Oct 16, 2013 | Microsoft Arc Keyboard
How to bypass immobiliser in 94 ford falcon after ignition barrel has been replaced ??
Your ford dealer visit may not be as expensive as you think, you need 2 pats keys and have them perform an ignition key code erase then they should be able to program your 2 new keys, The Ford Dealer I work at only charges 0.5hrs or approx $50.00 dollars Canadian.
Jan 12, 2012 | Cars & Trucks
My B, N, and spacebar keys are not working. How do I fix it?
Did you spill something on the keyboard? It could have dust etc particles that are preventing full contact or the keyboard itself may have a problem.
Turn it over and very carefully pat the back to dislodge any grit that may be under the keys. Don't whack it full force, just slap it gently. You can also carefully blow it out with canned air. If that doesn't do it then chances are the keyboard has a problem and needs to be replaced. That requires taking it apart and replacing it with a new keyboard which has to be for that specific model. Not a job to do yourself unless you feel confident taking a laptop apart...
Apr 09, 2011 | Dell XPS M1530 Notebook
I have a maytag gas dryer (Model DG303) that takes forever to dry clothes. The flame ignites but I don't know how long it stays on. The exhaust tube usually does not get very hot. Most loads take well...
I suspect you have intermittent gas valve coils. These are very common to fail, usually fail intermittently, are inexpensive and easy to replace. You will need to remove the front panel to access them and they are on the LH side once the front is removed. Replace both coils.
http://aplusapplianceparts.com/searchquick-submit.sc?keywords=279834
Dec 29, 2010 | Dryers
McCulloch 3200 hard to start, I think spark is weak. Like new.
It sounds like the coil is bad.Thanks for asking and I hope it helps
Jul 20, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I can only use my channel up and down buttons to navigate on my remote control. Why can't I just press 2 or 50 instead of going thru 2-001, 5-001, 002, 003, 7-001, 02 etc to get from 2 to 50?
Take the remote control apart, batteries out, pop apart, (any screws? - remove them.) Clean the rubber contact pad with mild dish soap and water, pat dry. Clean the circuit board with a soft towel and windex or equivalent. Clean the push button holes in the top cover with q-tips and windex. Reassemble, batteries back in. Test...Does this help?
Jul 05, 2009 | Sansui DTV1900 TV
Roper dryer ot drying very well
try cleaning out your vent hose that runs from the back of the dryer to the outside.
Feb 19, 2008 | Roper REX3614KW Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
Sal De
fordexpert
Robert Rankin
