Question about Panasonic Workio DP-150PA Copier
Help me on DP1820E panasonic photocopier
Hi, its my first time on this web.i have a problem with my machine panasonic DP1820E.showing a spanner.have checked alot but cant find the solution.please assist urgently.kind regards.bye
    Problem Solver:
  • 10 Answers
If there is no error message dont worry it just needs a routine service if it does have an error message what is it? it will start with an E example : e04-21 kind regards Dr Bob1
Posted on Mar 28, 2007
SOURCE:
My photocopier machine panasonic 8020 showing "ADD PAPER" when i already check all try of the machine pl give sutable answer. I awaited for your ans
u have to check the front door interlock switch.this is a common problem with the panasonic copiers .if u have a new interlock switch then replace it,if not then short ckt the same with the help pf a wire and thats all
Aug 03, 2011 | Panasonic DP-8020E Black and White Copier
Error code on Panasonic DP1820E
Sir,checkyour first paper draw ensure paper is properly placed also ensure no paper stuck behind the draw may require removing the draw to clear the paper power off then on the machine to clear the code once paper or what ever is causing the code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2010 | Panasonic Workio DP-1820E Copier
Panasonic DP1820E check printer E02-02 red spanner
yep!
e2-02 means there is a machine error of lifting motor assembly for tray #2.
For sure this time you can't use your tray #2.
you may check it sometimes there's just a paper clogged at the rear of the paper tray. just remove your 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Mar 14, 2010 | Panasonic Workio DP-1820E Copier
Spanner nut removel
Hi, The proper tool is P# TB123A.
You can also use a coal chissle and a hammer. Be careful that part of the spanner nut doesn't break off and hit you with the chissel. It takes a preety solid hit to losen the nut.
Hope this helps. If it does, please rate my comments and how I did in helping you. You can order the wrench as well as any other parts on my web site
http://www.whirlpoolpartssurplus.com/cart/
May 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The machine shows spanners
If you press the ' clear ' and ' 8 ' button, at a time both has to be pressed continuously then after two to three seconds you can see some code like "c44", "c43", c26, "c01".
the spanner means it is call for service. you have to call a service engineer if the symbol is blinking even though you may clear some of these with the codes.
These spanner blinks then it is saying that some part has gone bad and it need the replacement , service, reset of the code. any one of the three.
Nov 18, 2008 | Toshiba 2060 Copier
Panasonic Workio DP-1820P
Printer Error E02-01 appears when paper tray number 1 lift-up motor is unable to lift papers, Check whether the gear box of the motor is broken , normally replace the whole unit
Apr 30, 2008 | Panasonic Workio DP-1820E Copier
Help me urgently on DP6030 panasonic photocopier
I have a problem with a DP6030. code says J87. checked but can't find any paper misfeed.
May 15, 2007 | Panasonic Workio DP-150PA Copier
Panasonic Workio DP-150PA Copier Logo
148 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
