Question about Samsung Prostar DCS-24B-LCD Corded Phone
1 NEW MESSAGE SHOWING ON DISPLAY - folder empty
We have 1 New Message showing on the display in place of the user name, the problem is that the message folder is empty.. we think it is an internal call transfer message but do not know how to access or delete.
Advice please
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Hi unfortunately you are going to have to program a softkey to be a MSG key, when you have done this press the MSG key and delete the message- you can then re-program back to the original button. This video shows how to do this, go to http://www.abbeytelecom.com for more helpful videos relating to the Samsung Prostar
Posted on Jan 28, 2011
Resetter of samsung Ml3470 laser printer resetter
Try this...
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Jun 08, 2014 | Samsung ML-3470 Series
Tip
How to hide a user account
This tip will allow you to hide the user accounts from the logon window.
1.) Click "start" and "run".
2.) Type in "regedit" and press enter.
For those of you that interact with regedit, you might want to close all submenus before you go on.
3.) Go to the folder WinLogon.(HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsNTCurrentVersionwinLogon)
For those of you that have no idea what is in the brackets it's called an address. You'll find the folder called HKEY_LOCAL_MACHINE. Once you maximize that It'll have the folder SOFTWARE. The in the brackets is showing a new folder.
4.) Then go into special accounts and user list and you'll find certain keys(Thats what they're called)
5.) Create a new key by right clicking on the empty space, new and DWORD VALUE.
6.) Call it the user name you are trying to hide(it is case sensitive. It must be exactly the same. e.g. My user name is PapER BAg. The DWORD Name must be PapER BAg.)
7.) Make the value data 0 to hide and 1 to show.(Right click on the key and go to modify)
Once you've done that it will no longer show that user account until you change the value to 1 to make it show.
Was this helpful???
on Feb 09, 2010 | Computers & Internet
Does anyone know how to reset the toner levels in an HL3040, i have put new colour toners in and each is still showing empty
Hey, I've just figured this out myself. Here is the procedure:
1. Open the front cover that gives you access to the toners. 2. Press and hold "Secure Print" and "Cancel" at the same time. You will see "K-TNR-STD" display on the screen. 3. Using the "+" and "-" buttons select the toner you want to reset. 4. Press the "Ok" button. 5. It will display "Ok?" and hit the "Ok" button again to reset the toner. 6. Close the lid.
All done!
Regards, Michael Pasqualone TotalServe Solutions
Nov 01, 2010 | Brother HL3040CN Laser Printer
Cant change message tone on my sony eririsson mini xperia
The SD card has a folder named media, there is a sub-folder called audio, and subfolder to that is another called notifications. I believe you can also create ringtones and alarm subfolders below audio as well.
In the notifications folder place your new message tone.
To select the tone, choose settings, sound & display,Notification ringtone and pick your new sound.
Oct 03, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Showing name of contact of text message
Here is the user manual for your phone. Since all phone software varies, this should give the the information you need.
http://www.phonedog.com/cell-phone-research/samsung-sgh-e600_user-manual.aspx
I hope this helps and good luck!
Nov 04, 2009 | Samsung SGH-E600 Cellular Phone
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Samsung bio-sleep air conditioner. 1 ton capacity. the display is keep showing me 'ch'. How to remove that
press the temparature up and down key simulteneiusly for 5 seconds on the unit when it is on.It is CHOKE indicator stating that it is time to clear your a/c filter.It happens after ever335 hrs of use
Apr 29, 2009 | Heating & Cooling
File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project names. This will display all Folders & Files with that Project Name. You are looking for an .stx File. If it's there, right-Click on Project Name / Open Containing Folder & Copy it to your My Projects Folder. Then you should have both the Grey Folder & .stx File for the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one, by Opening a New empty Project, which will create a My Movie Grey Folder & a My Movie .stx File, Save to your My Projects Folder. Delete the My Movie Grey Folder & Rename the My Movie .stx File to the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under Documents\Pinnacle Studio\My Projects i then went through the following procedures using your great advice Colour;
  1. Make a copy of your found "lost" movie grey film icon file by right mouse clicking on your lost file and choosing "copy". Paste the copy into another folder in Documents where you can find it if need be
  2. Then go back to Documents\Pinnacle Studio\My Projects and right mouse click onto your grey film icon. Choose "rename". Then rename your "lost" grey film icon to a new file name but do not put .stc at the end of the file name, if you are operating VISTA and Pinnacle 12. This is important because Pinnacle 12 won't recognise the file later if you have .stc in the file name
  3. Open Pinnacle and go to the File Menu
  4. Click on New Project
  5. Open File Menu again and click on Save File as
  6. Give the file a name such as "Movie 7" and save it
  7. Close out of Pinnacle
  8. Open up Documents\Pinnacle Studio\My Projects and observe that you now have 2 new files there ...a grey film icon file saying Movie 7 AND a coloured Pinnacle icon file saying Movie 7
  9. Delete the grey icon file with the file name Movie 7
  10. Now give your coloured Pinnacle icon file the exact same rename as your precious "lost" renamed grey movie icon file, using the right mouse click on rename proceedure as explained in No.2 above.
  11. Close out of Documents file
  12. Now open up Pinnacle again
  13. Go to Menu and choose Open Project
  14. There you will see the coloured Pinnacle icon file with the new name of your "lost" movie file.
  15. Click onto its coloured Pinnacle icon, and watch your "lost" movie come into view again
Nov 16, 2008 | Pinnacle Studio Plus Version 11
Display shows "1 new/1 saved" yet mailbox empty.
The message left on your phone was probably left by someone internal, meaning they called your phone and when you did not answer, they hit their message key which turns on your message lamp and display. If you press your message key and it rings someone in the office then they are the one that left the message and they have to answer your call. You can usually cancel the lamp/message on your phone by pressing " Intercom ( your extension button ) " # 4 0 9 and then hang up. You can have up to four ( 4 ) messages on the phone so it may take putting in the code a couple of times to clear the display.
Jul 24, 2008 | Toshiba DKT-2010 Corded Phone
Samsung Prostar DCS-24B-LCD Corded Phone Logo
230 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
