Question about Sunbeam 2346 Heritage MixMaster Series Stand Mixer
Hot Air Gun (Power Tools made China) M z 6118-Bad function
Resistences are good. But only works on the first position,the lowest.
It seems to me that the problem is the TRIAC X 23 46 (pot:B 80 K double. The ventilator is good. Just don`t increase hot on superiors position of yhe dial.
Excuseme may poor English.
May I to obtein the TRIAC original? Or are there some any way for this problem?
Thnaks a lot.
Why doesn't it start?
Did you fit the brushes back properly, they are keyed on one corner and only go in one way. Check all the wires for continuity with a meter. Check the field windings for continuity as well. Make sure the switch contacts are touching in the on position. You need to track the power then (with your meter) and find out where it stops.
Nov 23, 2015 | KitchenAid Artisan Series 5 qt. Stand...
Where can I find beaters at the lowest cost for the KitchenAid Ultra Power Soft Start 7 Hand Mixer?
We sell the beaters at The Mending Shed, they are $8.95 for the set of beaters.
Here is a link to those on our website: http://www.mendingshed.com/kahandbeater.html
Jun 15, 2013 | KitchenAid Food Mixers
Cant seem to get the mixer attachment off its well and truley stuck tried all the suggestions in the instruction manuel but it just wont budge help!!!
The best way is to wrap a hot towel around the beater head, you have to get it hot to melt the "Gunk" that is acting like glue, I have actually had to use a torch once or twice, you can polish the stainless steel up again but you have to keep it away from the powder coated finish or it will bubble up and ruin the finish. The best but longest way is a hair dryer and a squirt gun, get it hot squirt it heat again, do it once or twice usually loosens it up and you can get the beater off, once you do use a non stick spray in the beater head before you use it and do not ever leave your beater on the mixer in the future.
Feb 11, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
I can attach the immersion blender attachment but it does not turn on. The machine works fine with the mini-chopper attachment or the beaters. How can I fix this?
Hi
Make sure you use the pulse function of the power switch. Only this position (forward, away from you) will activate the immersion blender, and then at full speed only.
Feb 09, 2011 | Braun M880 MultiMix Hand Mixer
Mixer won't shut off
Sounds as though the switch has shorted? Or the speed controller has failed ON. You could try a replacement if one can be had?
Feb 03, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer gets hot and smokes when in use.
Smoking and overheating during use does not usually indicate a problem with motor oil. Kitchenaid stand mixers have sufficient oil in them to lubricate the motor for its lifetime.
Smoking and overheating are geneally caused by overuse. Consult your use and care guide or Kitchenaid Customer Service to ensure the mixer is being used properly. Customer Service would also be able to send you a new Use and Care Guide at no charge.
Their toll-free telephone number is 1-800-541-6390.
Apr 26, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Mixer just won't turn on -speed control jammed
Unplug the appliance. Take it to a well ventilated area and spray some alcohol in the slot where the switch is while trying to move it. This must be done with the appliance unplugged and the appliance must be thourughly dry when you plug it in. Use canned air or if you have one a compressor.
Mar 05, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Sunbeam 2346 Heritage MixMaster Series Stand Mixer Logo
98 people viewed this question
Top Sunbeam Food Mixers Experts
Hjalmer Lamminen
Hjalmer Lamminen
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
