Question about Hitachi VME545LA Camcorder
Microphone not working on camecorder
I have a VM-E545LA and it hasnt been working in some time, i am an electronics engineering student and im trying to fix it but the microphone seems to be functional so my question is where do i go from here?
Pls can i get circuit diagram and description about Mifi...?
Electronics engineer student that can't spell Engineer??? I feel sorry for you man! Also, you wrote "Pls" for Please .....are you a lazy student?
Stop using shortcuts if you intend to be an engineer, and be methodical with your writing as well as your work.
Jul 12, 2012 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Please tell me whether it is a company for computer engineers or students from electronic & communication branch also??
Lufthansa is a global airline company based out of Germany. While technically not for computer engineers, it stands to reason that they would hire many. Students from electronic and communication branches could also probably find work in one of their business segments.
Mar 25, 2011 |
I think my onboard video card not working on asus pss800 vm because I get a NO SIGNAL when turned on.
make sure connection hasnt come out on either end (pc or monitor). Try installing a video card from a friend just to make sure it's not the motherboard causing the problem. Make sure it's enabled in the BIOS, sometimes it can turn off if bios is reset due to the battery going bad on the board.
Dec 20, 2009 | ASUS P5S800-VM Motherboard
I have an ASUS A8N-VM CSM motherboard with an Athlon 64 processor. I now want to use to edit home videos and to have voiceovers. I have tried several microphones but none of them seem to be recognised. I...
Have you downloaded/installed the specific drivers for the microphones and the motherboard? Although you have turned on the options within XP, there are often proprietary drivers that have to be installed and configured for the system to recognize the microphone.
Check the ASUS cdrom that came with your board and see if there aren't drivers for the board you will need to install.
Nov 19, 2009 | ASUS A8N-VM CSM (00610839133826)...
I got a new dell notebook and the microphone hasnt worked
your Dell us under warranty. Go to and work through the prompts to get them to honor your warranty and fix your microphone.
Sep 14, 2009 | Dell Inspiron 1525 Notebook
I inserted the jack into the slot and the microphone worked for some time. Now, it has become erratic, most of the time the microphone is not picking up my voice.
can be a loose solder joint on the jack or plug may be loose, try another device . not every person has a test meter but If you want to try a hand in electronics start at basic level, also any Ham Radio Operator is a great help who has been around the field for awhile or a student Electronics Engineer . Ok back to the fix it part are you able to solder ? the iron gets hot and saftey is # 1 thing and between burning yourself and the carpet , chair desk, etc I would ask for some help , don't try it on your own.
Apr 16, 2009 | Radio Communications
Microphone doesn't work
the jack of your pc has a hardware fault ,so it is not accepting the microphone.
Oct 26, 2008 | ASUS M2NPV-VM Motherboard
Problems with my MXL 990
Sounds like the frame of the microphone itself has become ungrounded. You could try VERY
carefully disassemble the mic and check for a bad ground or a bad wire connecting to the mic
Sep 11, 2008 | M-Audio MXL 990/991 Recording Mic Duo and...
need pre amp with it boost ya and to get it in sterio way should be are u running it direct in usb port and u have usb 2.0 outlets corect
Hitachi VME545LA Camcorder Logo
26 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
