Question about Sony VAIO VGN-FS640W Notebook
@nd function on keus
Hi, I use a VAIO VGN FS315E, during usage some keys when depressed display the wrong character and in some cases letters displays numbers. Do you guys know what could have led to this and how to diactivate it? However i discovered that when i hold down the "Fn" key while typing, the right characters are displayed.
  • 385 Answers
It seems like numlock is set to on. Check if the numlock light (near the power button) is on. If it is hold down the FN key and press "NM Lock" at the same time? Or it might be press FN key and then NM Lock after. You will see a light go off. Try typing again to see if you get the correct letters.
Posted on Mar 30, 2007
  • 60 Answers
It appears that the function key is stuck on. try an external keyboard. if the external keyboard has the same problem its an issue with windows but if not you could be looking at a replacement keyboard. hope this helps Peter
Posted on Mar 28, 2007
I have Sony Vaio VGN-BX660P laptop orginally loaded with XP Professional. My son gave it to me when its hard drive failed. I had the hard drive replaced and the OS upgraded to Win 7 Home Premium. But,...
You can settings multiple display on
Desktop .- Righ click
properties -.- settings multiple display
Choose Clone desktop (to show inage on both Projector and Display laptop
also you can create profiles
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Computers & Internet
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
What are the buttons meant for in the sony vaio vgn-fj180p above the keyboard S1 and S2
S1 and S2 buttons are called special Function keys.
By default, the S1 button turns the Volume On or Off and the S2 button toggles the display between the LCD and the external devices. You can also change these buttons assignments on the window for changing the S button assignments. To display this window, press and hold either button or launch and navigate through VAIO Central (Start, All Programs, VAIO Central).
Good Luck!!!!
Jul 09, 2010 | Sony VAIO VGN-FJ180P Notebook
How do I chance the names on an NEC phone
NAME DISPLAY
NOTE: Display Dterm
A name with up to 16 characters can be entered to display the name on
other Dterm telephones when making a call.
• Press Speaker key, Receive dial tone.
• Dial the Name Assignment access code and receive special dial tone.
• Using the keypad, depress the key with the desired letter to display the
first letter on the key. The
display will indicate the
numerical designation.
Subsequent depressions will
advance through the letters
on that key. The Dial Pad Key
TABLE can be used as a
guide to indicate the key and
the number of depressions required to display numbers, letters, spaces
and periods.
• When the desired letter is displayed, depression of the Transfer key will
change the letter to a lower case letter (default is upper case). Depress
the Hold key to enter that letter and advance to the next entry.
• Repeat the previous two steps until the desired name is displayed and
entered
Apr 05, 2010 | NEC Dterm DTP 16D-1 Corded Phone
White screen. what does it mean?
Your LCD might have gone out, call the sony support number for a service request or take it to your local computer repair shop. Hope this helps!
Jul 12, 2009 | Sony VAIO VGN-CR220E/P Notebook
Keyboard problem: multiple letters when one is pressed
sorry but even a small amount of liquid can work its way under the keys. you could try getting a can of compressed air to dissipate the liquid that has seeped under the keys, if not then you will need a new keyboard or take the keyboard apart
Jul 07, 2009 | Sony VAIO VGN-NR120E/S Notebook
Having troubles typing. Wrong characters com up...symbols display instaerd of letters. I did something.
just check the either ur keys wil be misplaced or goto keyword through control panel n edit the keys
Jun 03, 2009 | RIM Blackberry 8700c
Sony vaio keyboard fault
Hello, my name is Chris. Easy solution. Buy a new key board. Thats all you can do in this situation. There not worth trying to fix. A key board will cost about 10.00.
Mar 04, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
Sony VAIO VGN-FS640W Notebook Logo
401 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
