Question about Brother LS-2125 Mechanical Sewing Machine
What does it mean "refubricated"
I purchased the Brother LS2125 with 25 stitch options. It also had RB on the box, I think for refurbicated. What does that mean. Is it a new machine that has had parts replaced or a used machine that has had parts replaced?
  • jhpswife May 11, 2010
    Do you mean refabricated?
SOURCE: Brother sewing machine will not make continuous stitches
first you should turn off the machine and let in reset it's internal programs. Yes the feed dogs are very important. start your machine again...set the feed dogs...unthread and rethread teh machine from start to finish to include taking out the bobbin and replacing it. then make sure you bobbin winding in completely in Un using mode...
Posted on May 23, 2009
  • 52 Answers
SOURCE: Brother ls2125 won't zigzag stitch
that sounds like a timing issue if it will pick up every now and then i would recommend taking it to a brother dealer for repair as timing is not easy to set
Posted on Jun 26, 2009
bargainbox
  • 1388 Answers
SOURCE: HOW DO YOUI ADJUST TIMIMING ON A bROTHER LS2125
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Posted on Sep 07, 2009
  • 23 Answers
SOURCE: Why does the top thread on my Brother LS2125 keep
Are u certain u have the tension set correctly for the type material u are sewing?
Posted on Apr 12, 2010
SOURCE: can i purchase a free
try sewingpartsonline.com or sewingmachineparts.net
Posted on Dec 06, 2010
Can you also do regular sewing on a Brother HE1.
Supposedly this machine will do regular sewing too. It is a combination embroidery/sewing machine, so sometimes you do give up some benefits with multi-use machines vs specialized machines, ie embroidery. But that doesn't mean your machine was a bad choice. You just may not be able to do as many sewing functions or have the multitude of stitch options available.
Mar 01, 2017 | Brother Sewing Machines
Information on brother ult2003d machines
"So Long" means to increase the number of stitches.
Not filling in I'm assuming means you are missing stitches. Check underneath the fabric to see if the top stitch can be seen.
"No" will mean to increase the bobbin tension. The top tension should be on about four. This is the same bobbin tension that you are aiming for.
Oct 02, 2016 | Brother Sewing Machines
New Consew 146 rb 1-a Stitch length dial is set at
I would suggest taking the machine in to be adjusted and make sure they can work on that model machine, and if they can, then the same day you get it back, sew on it to make sure the problem is fixed.
Oct 23, 2013 | Consew 7360R-1 Mechanical Sewing Machine
I I my brand new brother xr-7700 manual says to look on page 49 -50 for monograming but NOTHING THERE
I think that you will find that monogramming is done free style, we used to lower the feed dog and put our piece to be monogrammed into an embroidery hoop then use a satin stitches and sew whatever we wanted. You can call Brother. I downloaded your manual (after looking at your manual) I see what you mean
Apr 16, 2011 | Brother XR7700
I own a Brother Innovis 1500D machine and I wonder if this machine can do the blanket stitch?
On most brother machines there is a feature called my custom stitch. You can create any stitch there and save in a memory pocket for later use. I dont think the machine has a blanket stitch so its the only solution.
Derek
Jan 11, 2011 | Sewing Machines
What does E3 mean on a Cs6000 Brothr machine? I do not have my manuel
Hi
Here's a copy of the manual from the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
Look on page 64 of the PDF file for the error codes.
I think E3 means:
Problem: The buttonhole or bar tack stitch was selected and
the foot controller was pressed (or the start/stop button
was pressed if the foot controller is not connected)
while the buttonhole lever is raised.
Solution: Lower the buttonhole lever
before continuing the operation
Sep 24, 2010 | Brother CS-6000
I have a 15 stitch Brother and I cannot figure out how to use all the stitches. The manual is of no use. I cannot get into the other circle of stitches that are available after 8 or so.
You are not making it very easy to help you. I think you should talk to a person who sews, because I never heard of someone who cannot understand a manual. Call Brother at 1-877-276-8437.
Sep 16, 2010 | Brother XL-5500 Mechanical Sewing Machine
How do I adjust the bobbin settings on my Brother XL-3022
Well is your machine skipping stitches? "Not looping" does that mean not creating a stitch? To adjust your bottom stitch you usually adjust the top tension regulator. I can try to help you more in detail check out my forums http://www.sewingmachineryrepair.com/forums/index.php
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother se- 270 D sewing machine reads a FO1 error. What does that mean..what is it code for? I went to the brother web site, but cant find an answer/?
I have the Brother SE_270D myself. 3 months after purchasing the machine brand new it started doing some really strange stuff like resetting itself in the middle of stitching out an embroidery design and it would take off on it's own while I was using just the sewing portion of the machine. The only way to stop it was to manually shut down the machine. Then I finally was able to get the error code F01 error. I had to call up the Brother customer service line and they could not tell me either, just that I must take the machine into an authorized service center. Upon doing so I was told that one of the circuits on the boards inside went bad, it would usually foul-up when it heated up after about 15 minutes or so. They fixed it and thankfully it was under warranty. Hope yours is too. Need to have your receipt of purchase. I think it's within the first year. Hope that answered your question. Good luck.
Mar 23, 2009 | Brother SE-270D Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
27 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
