Question about Acer NSK8458AN Keyboard
Lost clip for the acer aspire 5920 keyboard
I have lost the F key clip which holds down the F key to the keyboard an i dont no were i can get either the F key its self or just the clip and i am not paying £30 for a full keyboard when at the end of the day i only need 1 key so please could someone help me??
    Problem Solver:
  • 13 Answers
Hi, I'm afraid you're most likely going to end up having to buy the whole keyboard.
As far as my experience goes you could probably snatch the clip if you find someone who has an old 5920.
Most manufacturers, and or dealers- doesn't sell single keys.
Posted on Dec 18, 2008
How to fix acer aspire 5920 left side key board ?
Sounds like the keyboard is faulty. Replace the keyboard.
Jul 29, 2015 | Computers & Internet
Lost my e recovery management system
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Oct 15, 2012 | Acer Aspire 5920-6727 Notebook
Keys qazwsx12 do not work on the keyboard for my acer aspire 5920 laptop
i would suggest you get a new keyboard. Has anything been spilt on it. The keys you have said, sound like a cluster that has gone within the keyboard. The keyboard shouldnt be to much. You can take a keyboard out of a laptop either by unscrewing some screws on the back with a little keybaord next to them, or you would need to carfully pry a cover next to the keyboard to show the screws that are holding it down.
Feb 22, 2010 | Acer Aspire 5920-6727 Notebook
How do i replace my keypad on my acer aspire 5920 laptop
hi
you have to remove the panel which is found above the keyboard. the two small speaker is found just under that. there is no screw, take something falt, like a screwdriver, pull and it will come out. you have to open the screen 180 degrees.
once that panel is removed you will see 3 screw which hold the keyboard, remove all screws, lift the keyboard slowly, u have to remove the data cable connected to the keyboard, which is found just under the keyboard
hope this will help you
Oct 24, 2009 | Acer Aspire 5920-6727 Notebook
Acer 5920 keyboard setup
there is a software that launch menager. the program controls the keys you talked bout. you need to remove LAUNCh MENAGER.
May 30, 2009 | Acer Computers & Internet
Acer aspire lost internet connection how do i connect
Look on the Function keys on the keyboard (the F1 through F12 keys) Do you see a wireless icon on one of the keys? If you do, then look for a Function (Fn) key on the keyboard. Press and hold Fn, while holding Fn, press the funtion key with the wireless icon (example: the wireless icon is on the F2 key; press and hold the Fn key, while holding the Fn key, press F2, release both keys).
Mar 01, 2009 | Acer Aspire 5735 Notebook
Spilled coke on the touchpad and keyboard of Acer Aspire 5920
Not so sure on the touch pad, but the keyboard is easy to remove. Make sure the laptop is switched off first.
There are a series of little clips holding the keyboard on. Look along the top above the F keys you will see 3 or 4 little clips, push each of them in and up (away from the keyboard) using something thin and blunt so as not to cause any damage.
There will also be some little clips each side of the keyboard, these do not push in, you need to manoeuvre the keyboard past these.
Lift the keyboard from the top as it slots into some grooves at the bottom. There will be a ribbon cable connecting it to your laptop, this is easily undone and the keyboard is off.
Jan 25, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5920 keyboard replacement
http://www.gadgetsmanual.com/aspire-5920-series-users-guide.html THat should be whatcha looking for. Good luck!!
Oct 15, 2008 | Acer Aspire 5920-6727 Notebook
Acer keyboard messing up
Fantastic! I was just having the same problem when I read this article and pressed FN+NumLk(F11), then the keys started to work properly again.
Jan 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer NSK8458AN Keyboard Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
