Hp 2015d will not print. Everything is on and the driver is installed. We have also tried to reset printer. Powered it down.
  • granbbb Mar 25, 2009
    my hp laserjet p2015 wont print. i have sucessfully instaled it but when print command is issued, the cancel signal blinks and nothing prints.
    the usb port is detected and working well
  • 66 Answers
Hi Tmthymngn,
When printer is ready. Press the Green button. A Demo page will be printed. If this works, try to connect printer to a different USB port on the computer. Computer should detect that you have a usb connected. Or connect a USB drive to the port instead. If the drive is not detected, the USB port might not have been activated. On your computer, click Start|Settings and select Control Panel. In control panel, double click on System, then select Hardware tab. Click on Device Manager button. In Device Manager window, look for Universal Serial Bus Controllers. Click on the + sign. Right Click on each host controller tand select properties to see if each is enabled and working properly. If it is disabled, enable it.
Rgds
S88
Posted on Dec 19, 2008
HP 2015d While trying to print there is a gutteral noise on the first pass then the paper is picked up on the second pass and then the printed document feeds out. It appears to miss pick up on the first...
first you can try to clean the paper pick up tire, but most likely the problem is in pick up clutch.
TO replace him and rectify the problem you need to dismantle half of printer... call service...
Hope that helps!
Aug 23, 2011 | HP LaserJet P2015dn Printer
Moving an HP 3005p dn printer from our accounting department (which was networked) to my desk to print directly from my pc to the printer. Will it work? I am on Windows XP and Office 2007
Yes this will work as long as the printer has a USB port on it and you have the correct drivers for the printer installed on your machine.
You may need to factory reset the printer depending on how it was set up networked.
a NVRAM initialisation resets everything in a cold reset plus serial number, page counts and EIO cards - use with caution.
0. print-off a selftest/configuration page first to reset things if necessary.
1. remove all installed accessories.
2. power off printer
3. power on printer. When the memory count begins, press and hold the "down arrow button - keep holding the "down arrow" button until all three control panel lights flash once then remain on (can take upto 10 secs)
4. Press the "Up arrow" button.
5. Press the Menu button - the display should show SKIP DISK LOAD
6. press the "UP arrow" button until NVRAM INIT is highlighted
7. Press the "tick" button - the printer continues its power-on sequence.
Hope this helps
May 04, 2011 | HP LaserJet P3005 Printer
I have a new computer with Windows 7. I installed the HP 3500 driver and now the printer won't print. I hooked up the printer to my old computer that ran the 3500 and now the 3500 won't print from that...
If it no longer prints to the old computer, begin by powered down the printer and unplugging the power for at least 1 minute.
Hook it back up to the old computer powered down.
Once powered back on, goto control panel, printers and make sure that printer is set to default.
Try and print again. If it works moving on to the other computer make sure you are using the correct windows 7 driver (32 bit or 64 bit) if you are using the correct one I would try and install the vista driver instead as windows 7 and vista are quite similar
Lets start with that If you still need further assistance please leave a comment Thanks :)
Nov 21, 2009 | HP Color LaserJet 3500 Printer
I want to hp leserjet printer 2015d driver
plz check the manufacture website for the drivers
Apr 21, 2009 | HP Office Equipment & Supplies
Unable to print both side though requested
as i know, usb-printers don't support both side printing. It is words of the generant
Sep 24, 2008 | HP LaserJet P2015dn Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
Driver issues
Somewhere during the software install something went wrong. So every time you start the printer it thinks the drivers needs to be reinstalled & it finishes by installing its self again. Open the control panel & uninstall everything that the 3180 has installed on your PC including other perk programs bundled with the printer. Unplug the printer & Re-start the pc when finished.
Go to the link below & download HP's latest software for your 3180.
Follow the manual's instructions to the letter for re-installation.
HP3180.:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1146331
When you finish the install re-start the Pc. Go back to the HP site above and click the link you see there to: Automatically check to see if the latest driver is installed correctly.
Please vote....
Jan 16, 2008 | HP Photosmart C3180 All-In-One InkJet...
Cant scan from hp 3110 photosmart printer
You are having hardware communication problems caused, very likely, by driver installation troubles. Go into CONTROL PANEL and then SYSTEM and then DEVICES and look for the scanner there under IMAGING DEVICES and check to see if it has an exclamation mark next to it, or if any other device has this mark, meaning that drivers are not installed for it. If there is no scanner but you have a warning icon labeled UNKNOWN DEVICE, this is the problem. If you find any non-functioning hardware devices, this is probably it.
Try this as a fix. Unplug the cable to the printer/scanner.
Go online to HP and download the latest drivers and utilities for the scanner/printer and save them to your desktop.
In CONTROL PANEL, open ADD REMOVE PROGRAMS. Scan down and remove (uninstall) anything related to the HP printer or scanner, everything. Then reboot. Then install the drivers and utilities on your desktop you saved previously, plugging in the unit when prompted to do so. If you are never prompted, plug it in at the very end when everything is installed. If this routine fails, try rebooting the system without the HP scanner plugged in, wait for a complete start-up, and then plug the scanner into a different USB port and follow the directions on screen taking note of any failure messages. PS: the scanner/printer needs to be powered on through all of this, of course. :>)
Good luck
Nov 16, 2007 | HP Pavilion dv4000 Notebook
391 people viewed this question
jasbo
jasbo
