Question about Canon imageRUNNER 210S Copier
E000 switch off and on errer000
    Problem Solver:
Change the heater
Posted on Dec 19, 2008
  • 318 Answers
You can go into service mode to clear it.You can reset it but if the problem presist then the heater lamp is faulty.
Service mode-
Press usermode star,press no2 and 8 at the same time,press usermode star again,select copier,select funcktion,select clear,select ERR and press ok,switch machine off at wall for 1 min and switch on again.
Remember if this does not work the heater is blown.
Posted on Dec 18, 2008
How can repair an error of canon 2202 E000-0000 error code?
The E000, E001, E002, E003 and E007 are temperature error codes. Fixing these errors are necessory part of every
photocopier and printer. It is usefull to apply high temp and pressure to melt toner into the fibers. follow these steps
to reset E000, E001, E003 and E007.
Enter into service mode by clicking on key "2" and "8" the SSSW will display
Change bit switch 1 to bit 0
Press OK
http://canonprintersupport.us/
Sep 05, 2016 | Canon Office Equipment & Supplies
Error E000
E000: FIXING UNIT PROBLEM
replace or repair the fuser unit:
The fixing temperature is very low:
• The thermistor has poor contact or an open circuit.
• The fixing heater has an open circuit.
• The thermal switch has an open circuit.
Jun 17, 2015 | Canon Office Equipment & Supplies
How to solve error E000 0000
E000 0000 = The reading of the main thermistor does not reach 30 degrees C 1 sec after the main power switch is turned on. Or, it does not reach 70 degrees C 2 sec thereafter.
In other words, the fuser, or the section that heats up to melt the toner on the paper, is not heating up.
Jun 19, 2014 | Canon imageRUNNER 6020 Copier
System Error E000
press *28*, select copier, err,clear,ok. switch off the copier and switch on after 60secs. hope it works.
Nov 28, 2012 | Canon imageRUNNER 1600 Laser Printer
Error code E000 on canon photocopier means
the thermal switch is open. you need to check this part first and if it's open you have to replace it and then erase the E code in service mode-function-error-ok.
Apr 15, 2012 | Canon NP 6050 Copier
System error E000
E000 0000 The reading of the main thermistor does not reach 30oC 1 sec after the main power switch is turned on. Or, it does not reach 70oC 2 sec thereafter
Nov 03, 2009 | Canon imageCLASS D761 Copier
Hello, My Canon CLC 900 is showing E061 after it starts up? Any suggestions?
E000–0061, 0071, 0081
1) Clear ‘E000’. Is ‘E000’ indicated immediately after the power
switch is turned on?
• Be sure to turn off the power switch as soon as you have made the
check.
NO: Go to step 3.
Oil thermistor (TH5), Oil heater thermistor (TH6; short circuit), DC controller PCB
2) Turn off the power switch, and disconnect J6019 from J2209 on the
DC controller PCB. Measure the resistance between a and b of the
following table in reference to the detail code; is it 1 Kω?
Code a b
0061/0081 J6019-B5 J6019-B6
0071/0081 J6019-B10 J6019-B11
AC driver PCB
DC controller PCB
3) Replace the AC driver PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Oct 17, 2009 | Canon CLC-700 Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Jul 16, 2008 | Canon ImageRunner 1600 Copier
Canon imageRUNNER 210S Copier Logo
87 people viewed this question
old marine
old marine
