Question about NetGear WGPS606 (WGPS606NAR) Print Server
Netgear Print server
Hey,
did you ever find the solution to always having to reboot your Netgear Print server. I am have the same issues. works great for an hour, then have to unplug and plug back in. Please advise. craig@winnerman.us
  • XDJ1 Feb 12, 2009
    Same Here
  • user-user Mar 12, 2009
    same problem here I'll try updating the firmware
  • 854 Answers
Manual Configuration of WGPS606 Print Server
Note: Before configuring the printer server please check if you printer is compatible. You may open this link to you web browser: http://kbserver.netgear.com/kb_web_files/N101216.asp.
1. Please make sure that the printer works when connected directly to the computer.
2. Confirm the wireless settings of your router. You should have the SSID, wireless security and IP address of the router.
For NETGEAR routers please follow these instructions to check the wireless settings:
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab and you may get the wireless settings on that page.
e. On the left side under Advance setup, click on the LAN IP setup and locate the LAN TCP/IP Setup. Underneath that is the IP address of the router.
Note: If your IP address is 192.168.1.1, then you may use 192.168.1.200 for your print server.
3. Please connect a computer to the print server. At this time, the router is not connected. The printer should be connected to USB1. The power, LAN port and LPT1 should be lit.
4. Assign static IP address to the computer.
a. Click on Start and right click on Control Panel.
b. When the Control Panel window opens, double click Network Connections.
c. Right click on Local Area Connection, then click Properties. When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then hit Properties button.
d. Change the option from Obtain an IP address automatically to Use the Following IP Address and enter the following:
IP: 192.168.0.50
Subnet Mask: 255.255.255.0
Note: Leave the default gateway and DNS addresses blank.
f. Click on OK and then Close. Exit out of all the Windows.
5. Ping the print server.
a. Click on Start and then Run. Type cmd and hit OK.
b. On the DOS prompt, type ping 192.168.0.102. This should give four responses.
c. If it gives request timed out or destination net unreachable, please turn off both print server and computer. Wait for few minutes, then turn it on again. You can also try holding the reset of the device. Then repeat steb 5.b.
6. If you are able to get replies, you may now open Internet Explorer and type 192.168.0.102 on the address field.
7. After hitting go or enter on the address field, it will ask for a login. (Please type in admin for Username and password for Password).
8. Click on Wireless Settings under Setup tab and we need to set the same SSID as your router.
9. Please also select the appropriate Wireless Security and type the network key or wireless password from the router. Then click on Apply to save the settings.
10. When you get back to the page, click Print Server settings.
11. Check Change to and set the following:
IP address: 192.168.1.200 (It should be on the same range as the router. e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). This will be the print server's IP address.
IP mask: 255.255.255.0
12. Click Apply to save the settings. We will get a Page cannot be displayed.
13. Set the IP address of the computer back to dynamic.
For Windows 2000 and XP:
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Local Area Connection and click on Properties.
d. Scroll down to Internet Protocol (TCP/IP) and click on Properties.
e. Select the option Obtain an IP address automatically and Obtain DNS server automatically.
f. Then click on OK.
For Windows 98 and ME:
a. Please click on Start, then Settings, and then Control Panel.
b. Double-click Network then select TCP/IP for the Ethernet adapter. Then click on Properties.
c. Go to IP address tab and select Obtain an IP address automatically.
d. Click on the Gateway tab and delete the numbers under the Installed Gateway.
e. Click the DNS Configuration tab, and then select Disable.
f. Click on OK. Windows will then prompt for a restart.
14. To set up a TCP/IP port to the computer, please follow these steps:
b. Double click on Printers and Faxes.
c. Right click the printer icon and go to Properties.
d. Click Port Tab and click Add Port.
e. Select Standard TCP/IP port. Hit OK or Next.
f. In the field for Printer Name or IP Address: enter the IP address of the Print Server and click on Next.
g. Select Custom and then click Settings.
h. Under Protocol select LPR, and for Queue Name, type L1 if printer is connected to the print server USB port 1 and L2 if the printer is connected to the 2nd port.
i. Click on OK, then Next, and Finish.
j. Lastly, please right click on your printer icon and select Use Printer Online. If this is not an option, disregard it.
15. Check if you can print through the print server.
16. If it is not printing, then please try to connect the print server to the router and check if you can print. If it can, then there might be a need to re-do the steps for wireless configuration of the printer server.
Posted on Apr 30, 2009
Networking/map network drive issues/remote printing issues
did you resolve this issue , beacause i have the same problem with a toshiba e studio?
Jul 18, 2013 | Computers & Internet
I had a PS101 hooked up to an older wireless router. It was working fine on my new Vista Machine. The router died and just installed a NETGEAR WGR614 Wireless Router 802.11g. Now it doesnt see the print...
This was more hastle than it was worth. So I bought a new print server (twice), neither worked either. Might be the router, but after spending 2 hours on the phone with INDIA, I said forget it and took it back, bought a parallel card and gonna hook it up with a cable!
Jan 01, 2010 | NetGear PS101 Mini Print Server Print...
How do I find the MAC address of Netgear PS121 Mini Print Server?
To locate the mac address of the printer server connect the printer to the print server and power it on and then press the diagnostic button on the print server for 10 seconds. It will send a print out to the printer which will have the information related to the MAC Address of the print server. Also, you may check on the bottom of the print server, and you can find the MAC Address of the print server on the bar code.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 27, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
WGPS606 does not like printers
Hi, visit the link below to check the compatibility list of this print server. If your printer is not listed then it means that it has not been tested with this print server and there is equal chances for its nonfunctioning with the print server.
for further support with any netgear product visit my.netgear.com
Do rate it, if it helps.
Regards
Anand
Aug 02, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Have a ps 110 netgear printer server Vista will not requnize it
I have no problem using Vista Home Preimum notebook that print to the NetGear PS110, and now the notebook upgrade to Windows 7 Preimum, it still works. All other computers using XP, Win 2000, all work fine with PS110. Basically, install the printer drivers to LPT1 first, then add a new local port with \\PSNNNNNN\P1, then it just work. no problem. (note that, you have to configure the PS110 using same subset ip address first.)
Mar 17, 2009 | NetGear PS110 Print Server
Wireless problems with HP 3180
yes..that scanner issue keeps on popping up. has to do with the print command that's either compatible with the netgear standard, or it isn't..flukey, and not consistent..you might address netgear on this issue, but I've seen it before, actually..
May 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
One page wasted before print out
Hi Ontheedge,
I really hate suggesting it is a Netgear issue, and dump it, Edge, but most of the posts I found on that Print Server is not good. I would check for a setting in the Manger software, but not sure where it is. These link suggest it is a Netgear issue.
http://forum1.netgear.com/showthread.php?t=17002
Dec 20, 2007 | NetGear PS121 Print Server
Epson CX5800F printer Netgear PS121 Print Server difficulties
Here is a workaround:
http://newsgroups.derkeiler.com/Archive/Comp/comp.periphs.printers/2007-08/msg00456.html
Another thing to try if it STILL doesn't work is
Printer&Faxes>>Properties>>Advanced>>"Print Directly to Printer"
Just remember to restart after you try both of these. The Status Monitor in it's current for (at least for me) simply sucks.
Dec 04, 2007 | Epson Stylus CX5800F All-In-One InkJet...
Linksys print server psus4 held
Check the "sleep" time...is it around 2 hours? Also, check the sleep time on the printer too.
Aug 24, 2007 | Linksys (PSUS4) Print Server
Open Questions:
NetGear WGPS606 (WGPS606NAR) Print Server Logo
592 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
