Question about Gateway (8008625) Cooling Fan, Heatsink With Fan
Gateway laptop fan problems
We have a Gateway laptop Mod # SA1 (M Series?).
Lately it's been auto-shutting-down on it's own..
The fan seems to work in "pulses", I.e. the fan noise
rises and falls almost as if it's struggling to breath!
Never had a laptop fan do this.
I think it's shutting down because the CPU's overheating.
Is the fan going bad?
Any help and suggestions are greatly appreciated!
Steve C.
  • Anonymous Mar 02, 2009
    i' ve the same problem of autoshuting down
    the solution that u've sugested is a bit difficult for me to handle
    can u plzzz suggest a different but easy solution
    plzzz
    let me tell i am using my laptop from last year its new
    n i m very tensed with this problem
    plzzzzz help me out n reply as soon as u can
    thankss alot
  • 45 Answers
IF you trust yourself, take apart the laptop and apply a thin coat of thermal paste to the processor, and put it abck together. This should help.
Posted on Dec 21, 2008
I tell you :) the cause is the GPU and i have the same problem and i dont know what to do with the cooler cause the cooler may be the problem
Posted on Jan 24, 2010
Upgrade to windows 7 now wifi dosent work
Go here ---> http://support.gateway.com/us/en/product/default.aspx?partNumber=1015078R
And install the wireless driver (3rd one down in the wireless driver section)
That should get you working pretty quickly!
Mar 13, 2013 | Gateway Sa1 M-6750 Laptop Intel Core 2 Duo...
I have a Gateway Laptop M-series SA1 Video Drivers
This software Driver Update Software for XP Vista 7 8 contains your video drivers (and every other driver). wish you best of luck
Norman
Jul 21, 2012 | Computers & Internet
I have a gateway m series laptop. the cpu fan was making a bunch of noise. I don't know much bout fixing laptops but i opened the panel n took the fan out completely blew out the dust and put...
if your pc shuts down in 10 second with black sreen it means that your laptop memory was not detected. solution: reinsert your laptop memory (RAM) .. be sure to clean it especially at the contact points.
Jul 05, 2011 | Gateway Computers & Internet
I'm user gateway nv48 but my problem now my laptop always auto shut down when i play games. if surf internet it not happen like that.if i put my laptop in my hand and put it not flat , my fan laptop create...
Your computer is shutting down due to overheating. Since the fan is making noise it is not working or cooling correctly either because it has lint or debris interfearing with the fan blades, ot the fan bearing is going out. To determine this you need to access the fan and clear it of any blockage. You will need to remove the keyboard to access it. Not all Gateway models are the same but once under the keyboard you should be able to work with it. CLICK HERE for keyboard removal instructions. If you find lint or dust blocking the fan exhaust at the heatsink and can clear that out your laptop will run much cooler and should solve your problem. If the trouble is with the fan itself you can still find a replacement and be able to swap it out.
(if the removal of the fan requires removal of the heatsink assembly you will also need to apply new thermal compound between the CPU and heatsink after cleaning the old compound off with rubbing alcohol.)
Apr 25, 2011 | Gateway Computers & Internet
My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Jul 17, 2010 | Gateway Computers & Internet
Sa1, screen black I can here the cd and HD working but screen stays black. how can I fix? M series gateway. laptop
Please perform the following steps to resolve the issue:
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer.
Alternately you can test your Notebook power by removing and inserting the Memory and Hard-Disk iin their locations.
May 25, 2010 | Computers & Internet
Cooler Problem ?
There are devices you can purchase which aids in pulling more air through the system and keeping it cooler. One which I purchased and am quite pleased with is by Antec. It is a dual fan unit that is powered by one of your USB ports. You place your laptop on top of the unit, power it on, and it works wonders at keeping your system free from damaging heat buildup and those annoying shutdowns!
There are other units made by other manufacturers available as well. Some more expensive, some less. I have always had good luck with products from Antec and their price was reasonable as well.
Jan 24, 2010 | Gateway MT3422 RTL Notebook
M6307 Gateway Laptops overheats and shuts down
Have you called Gateway? This is definitely a mother board or CPU problem, both probably caused by a slow acting fan. Gateway should replace these.
Jan 05, 2009 | Gateway M-6307 Notebook PC
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
Gateway (8008625) Cooling Fan, Heatsink With Fan Logo
4,464 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
