Question about Toshiba Satellite M105-S3041Notebook
My machine is just rebooting time without number. after i deleted some files from the temp folder. can you help get the windows xp3 to update it. thanks bright.
  • Anonymous Jan 17, 2009
    laptop log out after entering user name and password
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 116 Answers
The file deletion may not be the issue. You may have some sort of virus or spyware interfering with the system boot. You may have driver or setting that is not fully resolved from an update. My initial suggestion for a solution would be to restart in Safe Mode, wait for the computer to fully load all of the basic drivers there, then just restart in normal mode and see if that fixes it. The next suggestion is to restart in Safe Mode with the Administrator account and load an earlier System Restore point. After that, it gets complicated.
Posted on Mar 22, 2009
How to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
Aug 30, 2015 | Computers & Internet
How to Optimize Your Computer
This is a tip on how to Optimize you computer for optimum performance
Windows XP
  1. Click Start
  2. Click run
  3. Type 'temp", make sure no browser/folder are open
  4. Select all file by pressing Ctrl+A
  5. Press Delete button to delete the files
  6. Repeat step 1 & 2, then this time type 'prefetch' repeat steps 4 and 5
  7. Repeat step 1 & 2, type '%temp%, repeat steps 4 & 5
  8. Then reboot the computer
  9. After reboot repeat steps 1 & 2
  10. Then type 'msconfig'
  11. Click on Start-up tab
  12. Then click on disable all
  13. Click on Apply and click close then reboot the computer again
  14. After reboot the compute should be running more faster.
on Sep 01, 2010 | Computers & Internet
Slow performance
First of all, SAVE ALL OF YOUR IMPORTANT DATA! Not programs, just Data. You can reload the programs.
Open Internet Explorer, Tools, Windows Update. Select Custom.
Install all the updates. Repeat until you no longer have updates to install.
Click Start, All Programs, Accessories, System Tools, Disk Cleanup.
While that is running open your TEMP folder and delete everything in it. Then open the Windows folder and delete all files starting with $NTUninstall. In the Windows\TEMP folder and delete everything.
After that I like to search for all *.bak; *.tmp and ~*.* files and delete them.(They're all temp files)
After all that Open My Computer and Right Click on the C: drive. On the Tools Tab select Check Now. Check Automatically Fix Errors and Scan For and Attemp Recovery of Bad Sectors. Click START and reboot your PC. This will take a long time. When that is finished, go back to Tools and Select Defragment Now. This also will take a long time.
This whole process takes a long time if this is the first time you've done it so, be patient.
Jun 06, 2012 | Toshiba Satellite U305-S2808 PC Notebook
How to make computer faster
1. Clear the temp files in the temp folder,recent files.
  • Click on Start and then Run.
  • In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
  • All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
2. Scan your machine with good anti virus every week with the updated definitions
3. Remove unwanted programs installed in the machine, as it uses unwanted memory.
Oct 12, 2010 | Computers & Internet
Toshiba laptop/satellite
Hi There,
With the viruses gone you need to do a little cleanup. I believe your browser is probably clogged with temporary files and that you registry needs tuning up. Here's the link for a wonderful little application that can do the job for you.
Ccleaner is a quick install and does not conflict with any other programs. Install it, run the Cleaner first without changing ANY of the settings, then click on the Registry square on the left side menu and just run it and say yes to every prompt. Then reboot.
After reboot, one last thing;
Hold down the Windows Logo key on your keyboard and press the R key. A Run Command window will appear. Type in %TEMP% and hit the Enter key. Your Temp File folder will appear. Left click once inside the folder window then use the keyboard command ctrl+A. All the files will highlight at once. Hit the delete key and let Windows delete as many files as it can. If it says one is in use and can't be deleted, just let it stay.
You should notice a difference after following these steps.
Good Luck!
Jul 14, 2010 | Toshiba Satellite A215-S4747 Notebook
Victim of software counterfeiting
After installing your genuine copy of Microsoft Windows XP you are prompted with a “Your software is counterfeit” error message at startup. Even after visiting the site and validating, you still get the above message popping up after 2 or 3 boots. There is an easy solution to this and I would like you to follow the steps below to fix the issue.
1. C:\Windows\Downloaded Program Files
  • Within that folder, remove any files or folders associated with .WGA
2. Safe Mode
  • Reboot your computer and as soon as Windows logs off, start repeatively tapping the F8 Key on your keyboard.
  • As soon as you see the Windows Advanced Startup options select Safe Mode within Safe Mode get yourself into these folders…
  • C:\Windows\System32 (Rename wgatray.exe to wgatrayold.exe)
  • C:\Windows\System32\dllcache (Rename wgatray.exe to wgatrayold.exe)
    Note: Dllcache is a hidden folder, to view hidden folders do the following, go to Start, Control Panel, Folder Options,
    Select the view Tab and under the Hidden Files option, select Show hidden files and folders
3. Safe Mode Registry
  • Click on Start, Run and within the open dialog box type regedit and click OK.
  • Within the Registry Editor navigate your self to
  • Right Click and Export the WGALOGON Folder (this should be saved onto your machine for backup purposes)
  • After Exporting the folder, DELETE the WGALOGON folder
  • After deleting close all applications and Restart your machine back to Normal Mode
After being prompt of a successful validation, Restart your Machine.
Oct 31, 2008 | Microsoft Windows XP Professional for PC
Window Update Problem
Follow the steps below to solve this annoying problem when the Windows XP updates will download but won't install.
Make sure Windows installer 3.1 is installed correctly
Click on the following link to visit the Microsoft Download Center and download Windows installer 3.1
Download Windows Installer 3.1
Reboot the computer and try to download Windows Updates, if they still fail to install, continue with the next step.
Stop the Automatic Update Service
Click on Start, Run
Type the following command and press Enter
Right-click on the Automatic Updates option in the Name column and click Stop
Close the Services window
Show Hidden Files and Folders
Open My Computer
Click on Tools, Folder Options
Click on the View tab
Under the Hidden Files and Folders section, select "Show Hidden Files and Folders"
Click Ok
Delete the Previously Downloaded Windows Updates
Open My Computer
Double-click on Drive C (or whatever drive Windows is installed on)
Double-click on the Windows folder
Double-click on the SoftwareDistribution folder
Double-click on the Download folder
Click on Edit on the menu bar
Click on Select All
Click on File on the menu bar
Click on Delete and delete everything in the download folder
Return to the SoftwareDistribution folder by clicking on the green up arrow on the toolbar
Double-click on the EventCache folder
Click on Select All
Click on Delect and delete everything in the eventcache folder
Restart the Automatic Updates Service
Click on Start, Run
Double-click on the Automatic Updates option in the Name column
Click on the Start button under Service Status to restart the service
Select Automatic under Startup Type to start the service each time Windows starts
Click Ok
Close the Services Window
Download the Latest Version of Windows Update Agent
Click on the following link to download the latest version of the Windows Update Agent and save it to your desktop.
Oct 18, 2008 | Televison & Video
Toshiba Satellite M105-S3041Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
