Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Yes. Two mounts work.I purchase on eBay. This lamp is Philips
UHP 100W/120W 1.3 . Syntax Olevia say this TV is old end
not have this lamp now
We replaced the bulb but still get the pop up message that the lamp life hours have expired. Is there a reset?
