Question about Kirby G6 Bagged Upright Vacuum
My vacuum takes off in drive
My vacuum, when it's taken out of neutral and put into drive, literally yanks you off your feet. I can't seem to figure out what is causing this. It's like it's posessed. Any ideas?
Some months ago I fell over my K-G6 at nite. Later the handle appeared looser than normal. Gradually, it started having the possessed yank-you-off-your-feet feel. This week I carefully disassembled the chrome plated cowling cover the handle goes thru to look inside. Two top machine screws when the front hood is lifted, two rear screws in the plastic, a single center screw near the drive-neutral toggle and a single screw for the power cord strain relief. I removed the handle by taking the two large screws off. This allowed the cowling to come free. From the rear, on the left side is a lever with a two pronged fork pointing up. The fork is supposed to stick into the receiver mechanism which is part of the handle slide. I get it: as the user pushes and pulls on the handle while vacuuming, the handle assembly slides back and forth and transmits commands thru the mechanical linkage to the drive mechanism. My fork was not engaged in the receiver. The reason was 3 screws on the left side of the brass block assembly were loose and the small black wedge was partially crushed. I dissassembled, cleaned, oiled and replaced the pieces and cinched down the 5 machine screws holding both brass blocks and the wedge. When I did this, I noticed the fork engaged with the receiver. Now reassembled, my Kirby runs pretty good and no longer feels possessed. And yes the roller height does make a difference on the drive assist reaction.
Posted on Jun 14, 2007
    President:
  • 1,462 Answers
You amy have the brush roll set too low so it is catching on the carpet. try setting brush roll higher and see what happens
Posted on Mar 29, 2007
SOURCE:
New belt now harder to push than before
the new belt already snapped is what it sounds like try taking it into guarantee vacuum and sewing center
Mar 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Brush Bar wont turn
Once you put it back together recline the vacuum as normal use and turn it on. If not working still the brush motor is burnt up. Needing replaced.
Feb 16, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
The n and the d on the bottom of the vacuum, what does it do? it looks like a switch of some kind. i bought the vacuum at a garage sale
This sounds like a Kirby vacuum cleaner. The n is for neutral and d is for drive. When you are using it the switch should be in drive. For moving it around, say into another room or closet, put it in neutral. If you turn the vacuum off with the switch in drive, the rear wheels will be locked.
Feb 25, 2011 | Vacuums
My Sentria always runs in the drive mode and it is so fast it seems out of control. If I push the neutral pedal it stays in drive. I can push it the regular way when it is turned off, whether the pedal is...
I sold vacuums for almost 20 yrs and the Kirby gets lots of complaints. The transmission that it has in it breaks as your has and they are costly.The best thing to do would be to take the maching to the local vacuum store(eg. sewing and vacuum are often in the same store).Bring it to a used vac store and they all repair kirby and thay can give you the best advice. I dont recommend going to kirby as thay will spend four hours at your house trying to sell you a newer model and they have not changed enough to get another one in hopes it will be betrter. Good luck
Oct 07, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum
before and my wife had the same issue. The neutral/drive pedal just fell
out so I figured I would give it a shot to see if I could fix it and
quickly figured out the 3 screws in the bottom plate for the drive
unit wasn't the answer.
I was able to figure things out out after I found
a parts list with diagrams at the follow web site and address:
Vac Parts Warehouse.com
http://www.vacpartswarehouse.com/category-s/2821.htm
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive
Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive
G6 558499A
Here's how to get to a point that you
can get these two parts in/out of the machine.
- Remove bag and fill tube from handle
and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws
at the handle fork plate (these have loctite on them so needed a
socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate
vie the screw with the power cord anchor and screw by the Pedal Cam
For Neutral Drive. Note release plastic tab in slot in the center and
lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the
power drive assembly so I could figure out how to put the dive
assembly back together. The pressed on arm that drives the cam
assembly had pulled of the pedal shaft so this also made it easier to
fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside. Note – continue disassembly below if bracket cam assembly will not come out as it is easier to work with once the drive assembly is removed.
Remove the screw on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam. Then the plastic back panel and the cam assembly should slide out if you lift up on it. Note that the screw is the only one with a star lock washer on it. Also note that this entire assembly is the only way that the parts are sold and it includes plastic back plate and metal cam assembly as. I when down the path to repair the existing assembly so I needed to take the power drive out The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts Warehouse.com. The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take
the power drive assembly out:
- Remove the 4 screws from the Cover
Shell assembly - the metal top part. You do not need to remove the
hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket
assembly that has the handle attachment and forward/reverse switch.
It attached by two wires. I only disconnect one and swung it to the
side.
- Snap off the the on/off switch and
disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom
plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now
drop out the bottom.
I just put the spring washer and arm
back on the shaft and reassembled. I'll see how long that lasts
before before buying the new part. Update: this fix did not last long. Use red Loctite or super glue to attach cam to shaft so it doesn’t pull out if you want to avoid buying the new assembly. Note that the cam must be aligned so that when the neutral side is pushed the cam will stop in the detent to hold it in place. Must be reassembled in the drive position as that is the default for the drive assembly.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
Gear shift fell out
This is an easy fix you do not have to fully remove transmission it does help to lower it down by removing screws. Then try to get the right angle and realign the splines I have fixed mine twice, the second time I put thread locker on it and have not had any problem. Steve
Apr 30, 2010 | Kirby Ultimate G Bagged Upright Vacuum
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Kenmore Upright vaccuum self-propel won't work/engage
No, I can't solve it. However, if you go to SearsPartsDirect.com you can find diagrams for this vacuum. There are three. You can click on "View full size", highlight the image, and print it by saying "Print selection" in the Print dialog box.
Perhaps by looking at how the thing is put together you can begin to figure out where the trouble is. You can also order some of the parts for this venerable machine (but not all of them.)
John
Indiana
Mar 21, 2009 | Kenmore Vacuums
Loud noise??
I have the exact same problem. I've taken the thing apart and cannot figure out what is causing the noise. It's not the belt and it doesn't seem to be coming from the engine. It sounds like the spinning brush is hitting something, but it's not, that I can see.
Jul 12, 2008 | Bissell 6590 CleanView Bagless Upright...
Kirby G6 Bagged Upright Vacuum Logo
142 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
