Question about Boating
Clouds of grey smoke and suphur smell when diesel engine starts
I have a ford mermaid 300 tubo plus diesel engine fitted to my boat and while it runs very well it is extremely smoky when it starts first and amoky a little when warm and idling
Try checking the fuel injectors to see if they are leaking.
Posted on Feb 02, 2009
Ford focus tdci not starting and white smoke coming out of the exhaust
It is a clear case of the glow plugs malfunction. It had happened with my neighbor who tried to start his diesel focus one day.
Even jump starting with another battery didn't solve the starting problem.
You could also check the EGR valve for damages and if you want to save a couple of bucks, then go in for used parts for the focus from Good used Focus Stuff
Mar 29, 2013 | 2001 Ford Focus
My mitshubishi 2.5 tubo diesel keeps smoking
If the smoke is grey, then you burn oil. Maybe from the piston rings, or from the valve seals, or from the turbo or a combination of the above.
Feb 11, 2013 | Car Audio & Video
My 2001 ford f350 diesel just started smoking out of the exhaust
Not bad Diesel or filter,injector more likely, your better off running a KOER test,(Key on engine running test) and do a buzz test on the injector,
Nov 26, 2012 | 2001 Ford F350 Super Duty SuperCab
My mazda 626 has a strong potent smell coming from the exhaust
You don't mention what that smell is reminiscent of?
You don't mention the colour of the "smoke" and you didn't say whether the engine is petrol or diesel?
You don't mention whether the road behaviour/performance is normal?
White smoke is almost always steam or in the case of a diesel it could be an unburned fuel mist, grey/black is excess fuel and blue or grey/blue is burning oil.
Some steam is fairly normal until the engine and exhaust system is hot but excessive amounts could be one symptom of head gasket trouble. If the engine is drinking coolant and sending it through the exhaust as steam it will sometimes smell spicy.
Burning oil smells a bit like burned eggs in the frying pan.
If the car hasn't ultra-low sulphur oil and fuel the catalytic converter will convert sulphur traces into hydrogen sulphide - the bad egg gas...
Sep 27, 2017 | 1998 Mazda 626
Car smoke with no smell and engine running rough
White or Blue smoke? Have you checked the oil to see if there is any water in it?
Feb 12, 2012 | Suzuki Cars & Trucks
Hi der,lost the turbo in my skoda first,den it started pumping out smoke after a wile,would it be da cat blocked by any chance??
No Chance at all, Its oil leaking into turbo from seal, Burned da tubo Eh. To check, remove turbo and start, loud as all hell but no smoke and you have found the problem, If not check piston rings, valves. ie check compression and check vacuum with gauge.
Oct 25, 2010 | 2001 Volkswagen Golf
Smoke
If it's liquid cooled then that grey smoke is more than likely steam ( the head gasket is on it's way out). If it was burning oil you would able to smell it.,,
Nov 10, 2008 | 2001 KTM EXC 300
2000 F-250 7.3 diesel, cuts out runs rough no power
Well, you have to let diesels warm up before you drive them so the engine gets warm and it may not sound right at first because if its not warm the compression gets off and doesnt fire right. If you try to give it too much gas before its warm, extra diesel will get in the cylinders and misfire. Then when it does fire, there is a lot of extra fuel in it so that causes the smoke and smell. You should always let it warm up for a bit before driving when you havent driven it for a while.
Oct 20, 2008 | 2002 Ford F250 Super Duty SuperCab
Boating Logo
144 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
