Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Pulling mechanisim seems to be jammed
The pulling mechanism which attaches to the garage door moves a couple inches then stops....even with the door not attached. The motor still runs. Motor will not stop until I manually move the mechanism to either end. It seems to be sticking on the track, but I don't know why.
  • 118 Answers
You have a stripped gear on opener. Take off cover and the bottom will be covered in white shavings. Replace with gear and sprocket assembly
Posted on Jan 18, 2009
After power outage, we had to pull the release cord to disengage the opener. Now that the power is back on, how do you re-engage the door with the unit so it will function?
These usually attach to each other with a slide lock. What you can do is command the door to stop within a few inches of the cord release. Then lift the door without pulling the cord until the door engages to the lift. It may take a little pressure and repeated cycles to get it to engage. Be sure that the cord release is not stuck. Cycle it a few times by pulling on the cord and watch the lock mechanism to make sure it is operating correctly. Your door is adjusted so that the opener senses a little pressure on the door to make sure it is completely closed. So if you just try to open and close the traveler may not quite make it to the disconnect. That is why you need to engage them manually. I hope this helps you. This is a real common problem with garage door openers.
Nov 01, 2017 | Building Materials
Garage door opener?
Limit switches may need adjusting. If it is a roll up type door, check the coil spring. It is usually mounted on the header above the door frame and will have shafts going out to the right and left with pulleys and cables attached at the outside edges attached to the door itself. The spring is what gives the mechanism the strength to lift the door. If the spring breaks, the motor will not have the power to lift the door completely.
Feb 20, 2015 | Building Materials
Garage door moves few inches and stops, springs are fine, sensros are fine.
If it is not blinking when it stops, then the capacitor is blown. Replace the capacitor and it should resolve the problem.
Aug 09, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Why does garage door opener only move a few inches?
Check the spring above the door, mine would go up a couple of inches and we found that the spring had broke.
May 16, 2014 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener model 139.53919
The torsion springs might need adjustment.
Pull emergency release, and manually lift door to half-open position.
When you release the door, it should stay in place.
If it almost "slams" down, the springs are not doing their job to "balance" the weight of the door itself.
The opener isn't designed to overcome the weight of the unsupported (no spring assist) door.
Over time, the springs take a "set", and might need a readjustment
THIS IS A JOB FOR PROFESSIONALS!!!
The springs are under tremendous pressure loading, and can even kill someone if they do not know what they are doing!
Feb 04, 2014 | Building Materials
Genie Powermax 1200 installed but only move approx 6 inches at a time.
You need to program the unit for up and down stops you can download the instructions from the link below
http://www.geniecompany.com/data/products/genie_programming-excerpt_eng.pdf
Jan 02, 2013 | Home Security
Chamberlain sent me a replacement board. I installed it. Now when i open the garage, instead of the carriage pulling the door back to the motor unit, it move forward about 4 inches, stops (because the...
Do you have the users manual of the system with you?Read it and follow the calibration instructions,it may take some trial and error to go through it,buts thats how we do it when we install a new or used garage access system.But of course you have to have some one to work with you cause you might be adjusting some pins or rollers,just an advice.
Feb 02, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
Door jams inwardley in the middle between 1st and 2nd sections
listen this door does not sound very strong may need replaced, but a quick fix is go to local lowes or hardware store if door is 10ft wide or less add a piece of 1 inch by 1 inch steel angel the width of door to problem section if it is over 10 ft wide ask help for a u bar strut to brace garage door this will be screwed to inside of door to give extra stability...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
63 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
