Problem transfering large files to WD 2.5" Ext HD using Windows
I can't copy large files to my WD 160 external. Windows says not enough space even though the hd is empty other than a few preinstalled files?
  • Joss_Apps Dec 18, 2008
    In the end we reformatted the WD HD to NFTS from Fat 32. Did the trick...
    Problem Solver:
  • 17 Answers
Might be split up into partitions, see how big your bios says it is, if you're using RAID0 that could be the problem.
Posted on Dec 18, 2008
File size limit for Buffalo HD 250 GB Hard Drive backup
The file is too large meaning that the size of that SINGLE file is too large. Your hard disk is probably formatted to a FAT32 file system, this results in a maximum of 4gb PER FILE maximum transfer. What you could do is archive it into a few parts using winrar and then moving it onto the disk, and when you need the file just extract the archive. Your problem isn't the total free space, it's the size of that file chunk.
Nov 03, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
Tip
Solutions to watch Blu-ray movies on Mac and WD TV
Not an easy thing for Mac users to play back Blu-ray movies, even they are your personal purchasing. I’ve summarized three ways that Mac users have usually used to playback Blu-ray movies as following. Frankly speaking, the former two solutions seems a little troublesome, personally, I prefer the last one.
Solution 1: With the help of AnyDVD HD via Windows:
Requirements:
- A Windows PC with a built-in Blu-ray drive or an external BD drive.
- AnyDVD HD
- A Mac: MacBook, MacBook Pro, MacBook Air, iMac, or Mac Pro
- Latest VLC media player or MPlayer
How-To:
1. Insert your Blu-ray disc to the BD drive, and run AnyDVD HD to remove copyright protections of your disc, no matter what kinds of protections your BD discs adopted, BD+, or AACS, AnyDVD HD is capable of dealing with them. Then you will get unprotected.m2ts files after the access of AnyDVD HD.
2. Copy the .m2ts files to an external drive or a USB stick, whatever, just let the Mac be able to read them.
3. Use the latest VLC media player or MPlayer to play unprotected .m2ts files.
Solution 2: Running Windows on Mac via Boot Camp
What you will need:
- A BD drive
- A Mac
- Blu-ray playback software on Windows, like Cyberlink PowerDVD 9 Ultra
How-To:
1. Install Boot Camp and Windows
I do not mention too much about this process, because Apple has already given the full direction about it here.
2. Connect BD drive with your computer, and Playback Blu-ray via PowerDVD 9 Ultra on the newly installed Windows OS.
Solution 3: Rip BD with Pavtube Blu-Ray Ripper for Mac
What you will need:
- A BD drive
- Pavtube Blu-Ray Ripper for Mac
This ripper provides directly copy function as well as HD video output option, so there is no need to worry about the output file quality of your Blu-ray movie.
The above two methods are all depending on the assistant of Windows, while the third one is not, thus I’d like to show the detailed operating steps about this one in detail.
Easy-to-use steps:
1. Load BD files through "DVD Folder" or "IFO File".
2. Select audio track from the pull down menu of "Audio", both Dolby TrueHD audio and DTS-HD Master Audio are supported.
3. Click the drop-down list of "Format" to select output format. Directly copy, HD video, iPhone, iPod, PS3, and many other devices and formats are all supported.
4. Click "Settings" button to adjust audio and video parameters like codec name, bit rate, aspect ration, frame rate, sample rate, and audio channels(5.1 channels is included).
5. Click "Browse" button to specify save path.
6. Click "Convert" button to start conversion.
Once the conversion is done, you are able to find out the output files via clicking "Open" button. If you choose directly copy, you can use VLC or MPlayer to play the output .m2ts files, if you converted to other usual formats, like mov, mp4, then you can use QuickTime player or whatever to play back them.
Via the Blu-Ray Ripper for Mac mentioned in solution 3, you can also absolutely realize playback BD movies on your HDTV with WD TV. Both WD TV Live HD Media Player and WD TV HD Media Player are all workable with .m2ts files, and they also support Full HD resolutions up to 1080P in common. In order to reserve the HD audio and video quality of your BD movie, you can completely select "Copy"> "Directly Copy" to just get the .m2ts files as the original as long as your USB device has enough space to store the output files. If not, you can also consider converting BD to a HD video format to save space as well as keep HD quality of the source file.
Well, hope the above contents are helpful.
on Jan 24, 2010 | Audio Players & Recorders
My samsung external hard drive can't copy large files
Well I would say make sure that the size of the file you're sending is lower than the available free space on your external hard disk.
And also, some ext. Hard disk has partitions, make sure your pasting in the right partition that has free space.
I hope this helps. Thanks for using FixYa!
Sep 11, 2012 | Computers & Internet
I want to back up my hard drive onto my Elements external drive. The computer says that the Elements 3607 does not have enough space. What do I do?
Well first of all check how many free space you have on your ext. drive. If you DO have enough to back-up your files,then i would suggest you right clicking on your ext. drive,choose properties and format it,but beware,formating will delete ALL your data on external drive.
If you think i was usefull,click on Thumbs up button,cheers!
Mar 07, 2011 | Western Digital Elements powered by WD 320...
Please help me ... how can i transfer videos from my Sony HDR-FX1000E Camcorder tape to save it into my laptop (SonyVPCEB1M1E)? i will be waiting to hear from you... thanks a lot.
Transferring video from your FX1000E should be quite simple using an HDMI cable. If you've recorded in HD, the files may be quite large, so make sure there's enough space on your HD to accommodate them or the transfer will error out (which might be the problem you're experiencing). Once transferred, the most recent version of Windows Media Player should be able to play them. You may want to convert them to MP4 files to save some space too. If space is an issue, think about getting a 1TB external hard drive to transfer them to. You can then plug both the FX1000E into your laptop and the external drive into your laptop at the same time and when capturing the footage save it directly to the external drive.
Dec 28, 2010 | Sony HDR-FX1000 Mini DV Camcorder
I need to make room on my internal ''C'' drive...was advised to move as many folders as poss to free up space. Have moved Pix, Movies, Doc, Links etc to my WD 500 gb ext HD, but cannot move desktop or...
Have you "emptied" your Recycle Bin?
From the "Start" menu, look in "Accessories".
One of the accessories is a "disk cleanup tool". Run it.
It will also delete all your "Temporary Internet Files" that Internet Explorer has created.
Now that you have "moved" your pictures and movies,
what will you do if your external hard-drive "dies",
taking your _only_ copy of those files to its grave?
It's time to buy a *NEW* "internal" disk-drive, e.g., 400GB for under $100 for a "laptop" disk-drive, reinstall Windows onto it, and copy (not "move") all your files from the external disk-drive to the new disk-drive.
Jan 04, 2010 | HP Computers & Internet
It isn't letting me transfer files that are larger than 5 gigs to my WD external HD. Says not enough space. How do I make it so I can transfer them?
Check to see what file structure the drive is formatted as. It's possible that it's formatted as FAT32 instead of NTFS. If that's the case, backup your data from the drive, reformat, and then you can transfer the data back to the drive.
Jul 31, 2009 | Western Digital My Book Essential Edition...
Cannot transfer files that are greater than 4GB
The lack of free space iis on your internal HD not the external. Whenever transferring files from one drive to another, you are acturally making a copy of the file to be transferred and sending the copy to the new drive. If your internal HD is nearly full, you can try to Cut and Paste the files to the external, or clear up more space on your internal b/4 tryiing to move the bigger files. Best of luck.
Greg
Jul 09, 2009 | Western Digital 500GB My Book World...
No space error
This is due to the file transfer limitations bound by the file format FAT32 (no files larger than 4GB and no folders that contain more than 1000 files). Try formatting the drive to NTFS.
Dec 30, 2008 | Western Digital My Book Essential 1TB...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
David Payne
David Payne
