Question about Kenmore 43042 Front Load Washer
Leaking....front door won't close
My front loader door won't stay closed, it keeps leaking water all over the floor..it is leaking from underneath the door when it is closed and then "pop" the door opens and the water pours out. Help? k
  • 1 more comment
  • Anonymous Jan 01, 2008
    the washer drum is leaking from the seam and from the front when draining/spinning. What needs to be done to keep it from damaging my floor?
  • KindaHandy May 14, 2008
    i have the leaky door too. I don't think it is the boot- I think it's the door mechanism that isn't holding the door tightly shut. Probably cuz I crammed a large load in recently... grrr.... ANyone know how to get to the mechanism?
  • Anonymous Mar 19, 2014
    front loader
    President:
  • 1,294 Answers
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Posted on Apr 12, 2007
My 4 yr old Whirlpool Duet front load washer is leaking water onto the floor from the bottom of the machine. It seems to be coming from underneath or back, it is not coming through the door. It's not...
The most frequent place for a front-loader to leak is on the door connector boot. The boot connects the drum to the door. You can often remove it and replace it upside down and that will give you a few more months' use.
Jan 23, 2015 | Whirlpool Washing Machines
My whirlpool amw8121 front loader won't spin. It
There should be a door-actuated limit switch which detects that the door is closed, which is probably defective. Look for the plunger, listen for the click. It is the most likely component to fail, and is inexpensive to replace if you're handy. Be sure to have your machine unplugged during repairs.
Sep 04, 2012 | Washing Machines
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
How do you change the front door seal on a LG 7kg front loader washing machine
Well I have the manual. If you want it.If the problem is water leaking out the door LG recommends you shim the door latch with washers. This would make the door close tighter and eliminate leaks. See page 36
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 12, 2010 | LG Washing Machines
When washing dishes the dish washer leaks water? lots of water
it sounds to me like you need to check the seals underneath the dishwasher.
Oct 16, 2009 | Dishwashers
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
Dispenser drawer opening on WAH6700AWW
try take the drawer out and clean the inside where the drawer fits into. It may have a build up of soap/softener etc.. then give the drawer itself a good clean including the bottom of the drawer. I have this problem from time to time where there is a build up of soap etc...
Oct 25, 2008 | Maytag Neptune MAH6700A Front Load Washer
Leaking
check the rubber connector around the inside of the door sometimes it gets "wrinkled" and keeps the door from closing correctly. also if it is leaking from around the door you may have a bad gasket if you are careful and patient you may be able to fix this with silicon sealer, squirt some inside the gasket where its messed up and mold or shape the silicone while its still "wet" to fit. Otherwise get a new one from www.danby.com
Sep 02, 2008 | Danby DWM5500 Front Load Washer
Maytag refrigerator
It may not be a water problem, it may be an air leak.
If there is something that is keeping the door from total closing, ice will build up from moisture.
check the gasket around the freezer door, or see if there is something that is keeping it from closeing completely.
Jun 02, 2008 | Maytag Refrigerators
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore 43042 Front Load Washer Logo
457 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
