Question about Kenmore 24032\24036 Top Load Washer
No agitation in the delicate and regular modes.
My Kenmore 110 series washing machine will not agitate in the regular and slow speed modes. It operates normally in the HEAVY DUTY (fast) mode.
When operated in any mode other than HEAVY DUTY, the water fills normally then, when it is suposed to start agitating, the motor just makes a clicking sound and there is no moement.
  •  Sherman
    Sherman May 11, 2010
    are you getting 120 volts down at the motor
  • 76 Answers
Does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Posted on Jan 01, 2009
  • Stacy Butters Sep 21, 2011
    None of those problems... It just makes a engaged noise (low grade) on then you can hear the timer going.. But nothing otherwise...
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
My washer is stuck in fast speed. Can't make it agitate in slow speed. Model # 110 26892690 .
I assume you mean spin.You should have a slow/half spin selection on your machine if not select a delicates or wool program this will give you a slow spin.
Feb 24, 2015 | Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Have a Sears 110 topload washer, it fills, agitates for appx 10 seconds, stops,wait for a few minutes, agitates again for a few seconds and stops. ??
this sounds ilke its in a delicate cycle or fabric care cycle...did you try putting this in normal or regular wash are the speed selectors set to fast/fast...let me know if this does not help...
Jan 23, 2011 | Kenmore Washing Machines
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore washer aggiates slower than when new. is
Usually, there are two agitator modes. A Normal ("Fast") mode, and a delicates ("Slow") mode. Put washer in 'delicates' cycle and see if the agitator slows down even further. If it stays at same speed as in perma press or 'normal' mode, then there is an open in the circuit betwixt the controller dial and the agitator control.
Feb 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
House circuit breaker trips when machine is set to delicate wash
Motor controller or motor itself has a short.
OR something stuck in the pump impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
318 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
