Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Status Light flashing yellow after replacing the bulb
Our bulb burned out in the WD-62327 with no warning. Bulb was cracked. we have replaced the bulb and now the status light is flashing yellow and the TV won't turn on. Any ideas?
  • 3 more comments
  • Anonymous Mar 12, 2009
    i have the same prob. out of no where my lamp went out so i replaced the lamp with a phillips lamp. same modal but now i have a flashing yellow light coming from the lamp indicator. any ideas?
  • coffeeadd181
    coffeeadd181 Jan 26, 2013
    I would check to ensure the lamp is properly installed and seated in it's bracket
  • Anonymous Mar 21, 2014
    Stays in status mode tv will not turn on
  • Anonymous Mar 23, 2014
    tv turns on with status light flashing. can hear sound but no picture comes on tv
  • Anonymous Mar 24, 2014
    light flashes yellow after a few mins.
  • 179 Answers
Your air filter cover is loose or not on.
Posted on Dec 18, 2008
We replaced the lamp in a tv mitsubishi wd-62327 now there is a orange flashing indicator light....now what?
if the set is now working,its just a matter of resetting the lamp-hour counter in the on-screen menus.be sure to clean any filters associated with the fan which cools the bulb,or your new lamp wont last long!
regards,steve
Jul 31, 2011 | Mitsubishi WD-62327 62" Rear Projection...
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
3rd lamp purchased within 2 yrs
There is a slight chance that you might have an issue with a defective ballast, I mean 3 lamps in 2 years, it's too much. The best way to go here is replacing the ballast, that might solve the issue.
Jul 25, 2009 | Mitsubishi WD-62327 62" Rear Projection...
AUDIO COMES ON, BLACK SCREEN, THEN TV SHUTS OFF?
This sounds like your bulb has burned out or has failed. Do you see a yellow or red light? If so, that is the status indicator that is telling you that your tv needs to be serviced. You can find a replacement bulb online. It is a fairly easy precess and you could probably do it yourself. If you need help with that, I have solved several "how to replace the bulb" questions. If you need help with that, look for those posts under my profile.
Jul 06, 2009 | Mitsubishi WD-60735 Projection Television
No pic with sound and turn off by itself with a
The red light is a status indicator that means your tv needs to be serviced. Most likely your bulb burned out or failed. You can purchase a replacement bulb online. I have solved a few questions on how to replace a bulb on this site. Check my profile for those posts if you need help with that.
Jul 01, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Blown bulb
time to change the bulb, the bulb doesen't last very long for the price that it cost. I have replaced three in mine in the past three years.
Jul 04, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Will not turn on
check to make sure that you didnt break the kill switches on both filter and lamp door. if one is broken you can just solder the wores together or put as jumper on it somehow.
Apr 06, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
883 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
