Question about Freezers
Custom freezer seal
I need a freezer seal cut to specific measurements. Where can i do this online?
  • 700 Answers
Refrigeration hardware supply. look for www.rhsc.net
Posted on Dec 20, 2008
Looking for a replacement seal measures 1040mm x 600mm
probably the best idea is to contact a local fridge/ freezer person that replaces seals on the doors of fridges and freezers (yellow pages for a start-fridge repairers)
they have an assortment of seal profiles on board and they make the seal to suit the door on site
The cost is about 75% of new price
ask the service agent spares for a seal, because although the freezer may be old , seals didn't change all that much and you may still get a seal from them
From the size I am guessing that it is a chest freezer probably an electrolux/email product and you may be lucky if it is
Mar 31, 2016 | Freezers
Compressor runs continously even after replacing the thrermistor and cold control. Any ideas?
Freezer not reaching cut off temperature.measure temp with a thermometer. -18 TO -20 should allow thermostat to cut off compressor.
Feb 15, 2016 | Frigidaire Freezers
Old whirlpool upright freezer. door left slightly ajar.light on inside. Rubber around door warm. won't seal.some things starting to thaw.shut door.should I do anything else
Seal needs to be replaced around door. Make sure magnetic strip is tight against sides of refrigerator, even if you have to cut the outside so it lays flat against the sides.
May 03, 2015 | Whirlpool Freezers
Need Seal replaced
Carolyn,
If this is a commercial freezer we offer a custom made gasket option. It's a simple process at coolergaskets.com
Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets.
Note: If you have a hard time with this we offer a $1 gasket sample ring.
Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our " How to measure your gasket" video.
Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands!
Oct 14, 2013 | Frigidaire 12 cu. ft. / 340 liter Upright...
I need a fridge freezer with external measurements H164cmxW73cmxD56cm. H could go up to 170cm. I want max freezer space, so at least 50/50split
You are going to have to do your own leg work on this one I think. Maybe somebody here can answer that question, however this is a repair forum and I can't memorize the dimensions of every possible fridge out there. My suggestion is to bring a tape measure with you to the appliance store of your choice, or look at online catalogs, they may actually list the dimensions you seek.
Oct 03, 2010 | Freezers
Bought a scratch & dent freezer. Door seal is not sealing properly, lets in air. How to fix? I don't see any dents near the seal, but lots of frsot and even drips are forming. I can plainly see when...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 03, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Door does not seal tight
Clean the seal on the metel and the seal real good with some steel wool or a good stiff scrub brush. If the magnates in the seal are pulled away for te metel to far you can take a blow dryer on high while pulling firmly on the bad spots and letting the dryer reform them. This takes a little time but may fix it until your ready to replace the entire seal outfit. Also for good measure just because>>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 27, 2010 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Temperature swing specification in a chest freezer.
It depends on the control that your freezer utilizes.
If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Freezer burn
freezer burn is the result of sublimation (the change of state from a solid to a vapor) In order to prevent/cut down on the rate of freezer burn make sure that all foods are tightly wrapped and/or sealed. The more are you can remove from the package before freezing the better. That is why vacuum sealing is so popular. Hope this helps
Sep 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
How to disconnect alarm when seal is not tightly closed
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Apr 14, 2009 | Frigidaire Freezer Refrigeration White...
Freezers Logo
43 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
